Understeer solutions? F21 135i
nigelkr1
Post by nigelkr1 » Wed Aug 23, 2017 1:35 pm
My 2013 135i came with new Bridgestone 050 runflats. They're ridiculously noisy on coarse surfaces and it understeers so relentlessly that roundabouts aren't fun.
I've seen the idea of fitting 225's on the rear, but what I'm thinking of is putting Michelin PSS on the front and Goodyear Asymmetric 3's on the rear. I'm thinking they'll end up with a similar actual contact area.
I know this mix n match is politically incorrect, but has anyone tried it?
Blind Pugh
Re: Understeer solutions? F21 135i
Post by Blind Pugh » Wed Aug 23, 2017 1:45 pm
Ditch RFTs and fit either GY ASY3 or MPSS 225/245 F&R
Set here FS
viewtopic.php?f=9&t=102527
AW M2 DCT
nigelkr1
Post by nigelkr1 » Wed Aug 23, 2017 11:42 pm
Okay I have ordered a set of the Goodyears. Just hope the front end bites better.
Post by marco_polo » Thu Aug 24, 2017 8:52 am
You need the longer front wishbones from a BMW M4 to get any kind of front grip, the stock chassis has so little negative camber it just understeers wildly.
Hoss
Post by Hoss » Thu Aug 24, 2017 9:07 am
As MP said...or SuperPro camber bushes to dial in the -ve camber of your choice. That said, all road cars are designed to understeer as it is more controllable than oversteer.
Post by marco_polo » Thu Aug 24, 2017 9:16 am
Agreed, I do keep forgetting about those SuperPro's. :oops:
sootyvrs
Post by sootyvrs » Thu Aug 24, 2017 9:21 am
Does the Superpro bushes increase track and lower the front, same as the M4 LCA's?
2018 F87 BMW M2 DCT
2017 F21 BMW M140i Auto
2015 F56 Mini Cooper S Man
2013 F20 BMW M135i Auto
2010 R56 Mini Cooper D Man
2007 E87 BMW 130i Man
Blind Pugh
Post by Blind Pugh » Thu Aug 24, 2017 10:03 am
Sooty
As you retain F2x LCA's the adjustable bushes will increase track and camber. I doubt adjustable camber bushes drop the nose in same way m4 LCAs do.
Bushes give circa extra 0.5 neg camber whereas LCA add 1-1.2 neg camber
When I retrofitted m4 TS to compliment the m4 LCAs the nose came back up again.
BP
AW M2 DCT
sootyvrs
Post by sootyvrs » Thu Aug 24, 2017 10:17 am
Sooty
BP
Thanks BP
The wheels I'm thinking of changing to are aggressive (8.5" ET38) hence wanting to know about the increase track (which may catch arches/bumper) which I may need a re-think and compromise somewhere :(
2018 F87 BMW M2 DCT
nigelkr1
Post by nigelkr1 » Thu Aug 24, 2017 1:28 pm
Thanks everyone I'll look into the Superpro bushes first I think :)
PS what are 'LS' ? LCA is lower control arm I assume.
Post by marco_polo » Thu Aug 24, 2017 2:54 pm
TS are Tension Struts (or brake reaction arms) - the longer curly wishbones.
nigelkr1
Post by nigelkr1 » Thu Aug 24, 2017 2:58 pm
Ah, thanks :)
GeeDee
Post by GeeDee » Thu Aug 24, 2017 4:32 pm
They look interesting to me as the M4 LCA probably gives too much -ve camber for normal driving.
By the way, I assume we are talking about Superpro camber bolts as opposed to bushes and, looking on OEMBMW, it seems that we need 10mm bolts which seem quite small. Is that correct?
Hexagon screw with flange M10X85 8.8 ZNS3 2 31306798530
Post by marco_polo » Thu Aug 24, 2017 4:40 pm
http://www.superpro.com.au/find/superpr ... 01544/vid-
Pretty sure they're M12 bolts, and 10.9 grade.
GeeDee
Post by GeeDee » Thu Aug 24, 2017 5:19 pm
