Tyre psi ?
jono400
Tyre psi ?
Post by jono400 » Tue Sep 26, 2017 1:36 pm
Any advice on correct tyre psi to run with the following set up on my e88 120D msport convertible ?
Front : 225 40 zr18 92y
Rear : 245 35 zr18 92y
18" zito 935 alloys
BMW 120 D msport convertible / E88
* Still looking for a set off Depos v2 *
AndyBish135i
Re: Tyre psi ?
Post by AndyBish135i » Tue Sep 26, 2017 2:07 pm
I've got the same Zito 935's but run 225 & 255 semi slicks.
I started at 35psi as recommended by Marco and adjusted to suit the feel I wanted.
Give it a go and see how you get on...
Try adjusting by a couple of psi at a time until you find what works for you :wink:
Re: Tyre psi ?
Post by marco_polo » Tue Sep 26, 2017 3:16 pm
Vert's are heavy, and so are diseasils. I'd start with 36psi all round for a week, and fine tune from there.
jono400
Re: Tyre psi ?
Post by jono400 » Tue Sep 26, 2017 9:57 pm
Cheers guys think I have them all set at 30psi so looks like at bit more required !
