TPMS - anyone bought some recently?
SimonB5
Post by SimonB5 » Tue Mar 27, 2018 5:56 pm
Needing a set of four ready for when my new wheels arrive. Anyone seen any deals out there, other than ebay for £120-140 a set?
Mineral Grey M140 - Auto - M Performance Exhaust
Blades1977
Re: TPMS - anyone bought some recently?
Post by Blades1977 » Fri Mar 30, 2018 8:46 pm
http://www.cartech-one.co.uk/
I bought one from here, was recommended in a previous thread. Fitted by the dealer no probs.
F20 M140i SE auto, black leather and alpine white
F20 M135i, manual, red leather and alpine white
Ja50nK
Post by Ja50nK » Sat Mar 31, 2018 10:14 am
Any reason you don't want to use eBay? If it is just a general uneasiness I got a set of four from the seller often recommended on here, and had no issues - arrived within a week and didn't cost much more than £100 for the set. BMW part number/stamp on the items. Thought it worth mentioning, but you may have other reasons which is fair enough.
Sent from my SM-G965F using Tapatalk
Sunset Orange LCI2 M140i, Auto, 5 Door, MPE
SimonB5
Post by SimonB5 » Sat Mar 31, 2018 3:02 pm
Nope, quite happy to use ebay. Just a quick check really to see if I could save some £££, I know the link posted back in January for Car Tech One had them at £84 for a set (I should've bought some then knowing new wheels were on the list!)
pmk76
Post by pmk76 » Fri Apr 06, 2018 6:24 am
Hello all
I’m in the same position, and found these on amazon. Do these have the same bmW part number (also available as a pack of 4)?
https://www.amazon.co.uk/dp/B07254N55S/ ... _lig_dp_it
I’ll check eBay now....
SimonB5
Post by SimonB5 » Sat Apr 14, 2018 8:58 pm
https://www.ebay.co.uk/itm/4x-BMW-TYRE- ... SwnNBXbtsV
Got a set of these for £90 in the end...all working fine after a TPMS reset.
Goon
Post by Goon » Mon May 21, 2018 5:28 am
Do these have to be fitted? Arent the wheels the same with one hole for the valve?
andyjhatton
Post by andyjhatton » Mon May 21, 2018 12:49 pm
I have these: https://www.ebay.co.uk/itm/182071149299
Work like a charm.
2015 M135i, Pre-LCI, 6MT, Adaptive, Birds ARBs & Quaife LSD, M4 LCA + TS, Bilstein B14, Goodridge lines
Nannerdek
Post by Nannerdek » Thu May 31, 2018 2:06 pm
I recently bought F30 and of course there is no spare wheel because it has the run flat tires.
______________________________________________________________________________
There are no solved problems; there are only problems that are more or less solved.
All the best,Nannerdek Diceus
