Beyern 19" x 9.5" ET 45 on rear of M240i ?
Jonjones13
Post by Jonjones13 » Wed May 16, 2018 5:13 pm
Beyern say it'll fit, dealers say it's too tight. Anyone have any real world experience of a 9.5" ET45 Beyern wheel on the back of an M-Lite?
2017 (17) MG M240i
Re: Beyern 19" x 9.5" ET 45 on rear of M240i ?
Post by marco_polo » Wed May 16, 2018 5:25 pm
With a 245/30/19 on, I'd expect them to bolt up without any rubbing (albeit with zero rim protection). Might even squeak a 255/30 back there.
Blind Pugh
Post by Blind Pugh » Wed May 16, 2018 6:03 pm
Given 9" et44mm is already snug am not convinced 9.5" et45mm would work with 245 let alone a 255 tyre.
AW M2 DCT
Goon
Post by Goon » Thu May 17, 2018 5:58 pm
Ask Beyern if they will give you a no quibble full refund if they don't fit and see what their response is.
Duncan.B
Post by Duncan.B » Fri May 18, 2018 1:23 pm
im running 19x9.5j et 45 rears with 255/30/19 lowered on H&R 2mm springs and no rubbing unless the car id fully loaeded :-P
Current- Valencia Orange M135i- MHD 2+, BMS Intercooler, Forge Chargepipe, Decat, H&R springs 25mm , 19” 763m Reps.
Past: M235i-JB4, Decat, Cobra Cat Back, OZ Formula HLT 437Hp / 472 Ft.Lb
Jonjones13
Post by Jonjones13 » Fri May 18, 2018 10:08 pm
Would you get 265’s on there?
2017 (17) MG M240i
Post by marco_polo » Fri May 18, 2018 10:50 pm
No way, 255's would be tight. Need ET50+ for 265's.
Duncan.B
Post by Duncan.B » Tue May 22, 2018 9:48 am
originally it had 265 fitted but couldnt get a finger in so was far too tight hence why i dropped to 255.
it can be done but wouldnt recommend it..
Jonjones13
Post by Jonjones13 » Tue May 22, 2018 10:17 pm
Others say a 265 on the rear 9.5” 45ET would fit...just throwing it out there...
viewtopic.php?f=74&t=109012
2017 (17) MG M240i
Post by marco_polo » Tue May 22, 2018 10:46 pm
They'd stick out the sides of the rear arches like a rollerskate, depends if you like the Carlos Fandango look?
Jonjones13
Post by Jonjones13 » Wed May 23, 2018 10:08 pm
Excellent :D
2017 (17) MG M240i
