The F20 Alloy Wheel Thread
Falltrack
Re: The F20 Alloy Wheel Thread
Post by Falltrack » Thu Jun 07, 2018 7:51 am
Alright great so if I go with the Wizards at 8x18 ET45 which tyre dimensions would you recommend?
And for the VMRs 8.5x18 ET40?
I'm not sure about the weights on the VMR V703s but they're probably around 22.5lbs/10.1kg which is what the V710s weigh. Either setup is lighter than stock anyway.
Post by marco_polo » Thu Jun 07, 2018 7:59 am
You can safely refit your stock tyres if you want, although the fronts will appear a little stretched.
I like to run 245/35 all round, but not MPSS as the 245/35/18 pattern doesn't clear standing water well.
Falltrack
Post by Falltrack » Thu Jun 07, 2018 8:29 am
Cheers, will go with 245/35 all around I think.
Unfortunately I have stock 17" 383M and almost new runflats on my 120d lci, got the car just a few weeks ago, the plan is to use winter tyres on those wheels and get rid of the runflats.
Ronburgundy1983
Post by Ronburgundy1983 » Sun Jun 17, 2018 10:35 pm
Team dynamics pro race 1.2
18"
8j
et40
* lowered on HR springs
Donz
Post by Donz » Tue Jul 03, 2018 12:20 am
Ok as ever I’m looking for confirmation!
I’m considering18x 8.5” all round et35 with a square tyre set up 235/40/18 - cup 2’s for track days. Too pokey?!
Clio 172 mk2, Impreza blob prodrive,Impreza hawkeye cosworth, 325d Touring, M140i and a ph1 172
Post by marco_polo » Tue Jul 03, 2018 6:58 am
235mm at ET35 shouldn't rub, assuming you're on stock wishbones?
Donz
Post by Donz » Tue Jul 03, 2018 8:08 am
All stock. I was using 15mm spacers anyway so minus them there is only a slight difference!! 235 on 8.5 shouldn’t appear ‘stretched’ should they?
Thanks again
Post by marco_polo » Tue Jul 03, 2018 8:15 am
235 on 8.5j will look slightly stretched. Perfectly safe, but next to zero rim protection so watch those kerbstones.
Mattyk
Post by Mattyk » Mon Aug 13, 2018 4:35 am
Hey,
Was looking for some advice for a stock suspension F20.
Looking to fit 19x8.5 ET45 wheels front and rear: http://www.bmraw.com/gtc-gt-cr-19-5x120/
Will be doing some light motorsport so can't afford any rub. Happy to roll guards if required.
Anyone have any experience with this setup on an F20? Looking to run 235/35 front, 255/30 rear tyres (AD08r)
Was thinking about going 19x9.5 on the rear, but think that'll be too close.
Thanks in advance!
Post by marco_polo » Mon Aug 13, 2018 7:49 am
Your fronts might rub on the struts, so I'd have a pair of thin spacers handy. Might need to roll the rear arches too, as R Spec tyres have rather square shoulders.
Mattyk
Post by Mattyk » Mon Aug 13, 2018 8:12 am
ah, ok. Nice one, thanks!
Speedreader
Post by Speedreader » Sun Aug 19, 2018 7:28 am
AddySY wrote:
Fri Jun 23, 2017 12:56 am
Duncan.B wrote:Mine and my friends OZ Formula and M3/4 Reps.
Beauty pic Duncan Image
I decided to go with black diamond cut after a short stint with the silver finish much prefer these Image
I really like the look of those wheels, can you share the brand and spec's please
Michael_S91
Post by Michael_S91 » Thu Aug 30, 2018 10:48 pm
Anyone can help please with brand,sizes etc. ?
Tricky401
Post by Tricky401 » Fri Aug 31, 2018 8:32 am
On addySY they are 18x8.5 et35 from skidz in Scotland. Possibly not on the website so will need to call. If you search his posts there might be more info
M135 5door, mineral Grey,black Dakota , auto, comfort pack + front Pdc, pro nav, adaptive sus, adaptive LEDs, reverse cam, sunroof, shadeband, sun protection, folding mirrors, load through, heated seats. First ever auto and BMW
Michael_S91
Post by Michael_S91 » Sat Sep 01, 2018 10:38 am
Tricky401 thank you for your help 😀
