Fitting F20 Halogen Headlight
silas greenback
Post by silas greenback » Mon Sep 18, 2017 4:20 pm
So the misses cracked the headlight on out 1 series (we always say it was the misses, but honestly it was)
https://photos.app.goo.gl/5T7GHXCJM5TTKbzq2
I have got a new headlight from cotsworld bmw, great service and price, thanks Phil! and attempted to fit it today, but i'm a bit lost with all of the adjusters
I was hoping to fit it basically and then get the light aligned properly, but it looks a bit of a pain as you have to remove the bumper each time you need to adjust the light by the look of it.
Does any one have a guide or service manual on basic setup
The light has two screw adjusters on the bottom of the unit
https://photos.app.goo.gl/mF0syYpj2X9rn9Pj1
and fitted to the car it looks like this
https://photos.app.goo.gl/dn7Aw11UtRmojYVs1
Lights are Halogen BTW
does any one know a start position?
Re: Fitting F20 Halogen Headlight
Post by marco_polo » Mon Sep 18, 2017 6:33 pm
Can't you set it up exactly the same as the one that came off?
Or take the drivers' side out and see how that's set?
Shouldn't need to remove it to adjust the beam aim, there are a couple of white plastic adjustment screws (might be 7 or 8mm allen key?) accessible from the top via holes through the slam panel.
Headlight Aim.jpg (87.87 KiB) Viewed 838 times
silas greenback
Post by silas greenback » Mon Sep 18, 2017 8:22 pm
Hi, thanks for replying
The one that came off lost its settings when removing the screws on the underside
I think the adjustment screws on the underside, top left and single boit right are just for making the Headlight fit the body, the actual alignment is internal to the lamp
