MHD Custom Maps
Moderators: babybmwadmin, Rich196, Producethis, Lambster, marco_polo
mehtaman
MHD Custom Maps
Post by mehtaman » Tue Jul 02, 2019 11:48 am
Hi All,
Is anyone aware of any MHD Custom Map ccompanies around in the UK?
TIA
| Motech Eibach Pro | ITG Panel Filter | MHD Stage 2+ | xHP Stage 2 | PCW Exhaust | Wavetrac LSD | MP Airbox |
| Richter 200 Cell Sports Cat | MTC FMIC | BMS Charge Pipe | EBC Yellow | Forge Boost Pipe | TPi Spacers | GFB DV+ |
Np01
Re: MHD Custom Maps
Post by Np01 » Tue Jul 02, 2019 8:30 pm
Have you emailed Momir at MHD, he always responds quite quickly
M135i Manual, mineral/oyster, MHD stage 1, carbon mirrors, MPE, full carbon trim, double slat grille, HK, pro Nav, Alcantara wheel, AC roof spoiler, on MPSS, Forge Motorsport Charge Pipe, Rieger rear diffuser. Bilstein B14s.
mehtaman
Re: MHD Custom Maps
Post by mehtaman » Wed Jul 03, 2019 8:33 am
Good point, I’ll message him on the MHD WhatsApp group.
williams
Re: MHD Custom Maps
Post by williams » Sat Jul 20, 2019 2:49 pm
Anyone should be able to map it, you don't use mhd to create the map. Pull the stock file from the ecu using mhd, then your chosen tuner will use their preferred software to open and edit your ecu's .bin file, then use mhd to flash it to ecu.
