MHD won't connect to dme
Mato
Post by Mato » Fri Jun 09, 2017 7:51 pm
Hi all just tried to flash my 2008 135i using mhd, it read the ecru initially and allowed me to buy the map. Tried to load the map and now the app is saying it cannot contact dme and car just cranks won't start. Any ideas? Thanks
jason@bwchiptune
Re: MHD won't connect to dme
Post by jason@bwchiptune » Fri Jun 09, 2017 9:23 pm
I've had a lot of customers bring there cars to us after trying to flash the ecu this way
If you check if the ecu has communications with a diagnostics to 1st
If it doesn't I would need your car or the ecu Cas and key sent down to us to fix the bricked Dme
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road
BW autorepairs
Over 30 year repairing BMWs
New and fully refurbished BMW Ecus and Cas units
BMW Keys made and cut same day
Correction of Engine ECUs Cas and key fitted to your car (key set from a different car)
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars
DPF repairs fixed without the need of removal
0208 561 1818
07831 103030
Hayes
UB3 1BB
Click here for: BMW Remaps
Click here for: BMW Repairs
DynoDynamics rolling road testing in london & newcastle
dealers across the uk
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
steveo08
Post by steveo08 » Sat Jun 10, 2017 7:45 pm
Try another otg cable. I had the same issue bought a cheap otg cable was able to read codes etc but when I flashed it failed and car wouldn't start. Got a new one from maplins and flashed first time .
2010 n55 135i space grey. Red leather. Bmwp exhaust and lots of bmwp goodies, Darklines. BMS chargepipe, wagner evo fmic, mhd stage 1+
rob180bhp
Post by rob180bhp » Sat Jun 10, 2017 7:46 pm
I had to try 2 different leads, one initially connected then failed, lucky I had spares
Instagram "rob180bhp"
AdamHarbour
Post by AdamHarbour » Sat Jun 10, 2017 8:09 pm
As above, get yourself a decent cable and try again, mhd should just pick up where it left off and recover it.
N54 135i | JB4 | VRSF FMIC | VRSF down pipes | N55 mids | BMS charge pipe + BOV | Stage 1 LPFP | BMS meth kit | Carbon bonnet | Reiger diffuser | Darklines | MHD race flash | spec stage 3+ Clutch | MMP Inlets | 470hp-560ftlbs | 12.7@115mph 1/4 mile |
