Nozzle Change for Diesels - Increased Performance
OK51MON
Post by OK51MON » Wed Dec 13, 2017 11:18 am
Over in the TDI club forums the first thing they do when looking to increase performance and mpg is simply replace the injector nozzles.
Anyone done this before ?
http://www.myturbodiesel.com/wiki/tdi-f ... ement-diy/
eddbluespark
Re: Nozzle Change for Diesels - Increased Performance
Post by eddbluespark » Fri Dec 15, 2017 12:26 pm
What you are looking at there is the procedure for changing nozzles on pre-PD VAG engines. (The PD engines they then progressed to were then replaced by common rail engines.) Those Pre-PD engines run a traditional distributor pump, and the injectors are not electronic whatsoever.
This kind of tech has never been used even in the oldest 1 series (they were always common rail), so any info you find for this type of setup isn't really applicable.
Best regards,
Edd
Bluespark Automotive Ltd - Plug and Play Tuning Solutions - See what we can do for your BMW here: https://www.bluesparkautomotive.com/bmw-tuning
jason@bwchiptune
Post by jason@bwchiptune » Sun Dec 17, 2017 11:22 am
Which car and year do you want more power from ?
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road
BW autorepairs
Over 30 year repairing BMWs
New and fully refurbished BMW,Alpina Ecus and Cas units
BMW Keys made and cut same day
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used)
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars
DPF repairs fixed without the need of removal
0208 561 1818
07831 103030
Hayes
UB3 1BB
Click here for: BMW Remaps
Click here for: BMW Repairs
DynoDynamics rolling road testing in london & newcastle
dealers across the uk
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
OK51MON
Post by OK51MON » Thu Feb 15, 2018 8:29 am
BW chiptune
BW autorepairs
0208 561 1818
07831 103030
Hayes
UB3 1BB
125D
OK51MON
Post by OK51MON » Thu Feb 15, 2018 8:30 am
Best regards,
Edd
Thanks for the info Add
HaiderGill
Post by HaiderGill » Sun Jul 01, 2018 8:22 pm
After about 100K the injector on a diesel car will be out spec, best getting them changed...
