MHD Users - Your Preferences
Neil-D
Post by Neil-D » Wed Aug 15, 2018 6:32 pm
Hi all,
I’ve recently downloaded the MHD App on Android and loaded up a Stage 1 map for my EWG M135i. Instant difference from stock - other than running an MPE and so far very pleased with the gains. Their latest info suggests 379bhp with just a map using 95 Ron.
I’m just curious what others users think of MHD and where your settings are. For those that don’t know, the App is on Android and you pay for Maps through Google Play. It connects to the car through the OBD2 and you can make some adjustments to the car like remove the increased noise on cold start as well as adjust exhaust ‘burble’ if you want it ranging from minimal to loud and aggressive. You can also buy various other maps if your car is modified with sport cats, de catted etc or if you go down this route at a later stage.
I have the Stage 1 map as my car only has an MP exhaust with the exhaust burble switched on with the following settings
Duration Base (I think this means I’m comfort mode) - 0 seconds
Duration Sport - 1.5 seconds
Aggressiveness - Medium
Cold start noise reduction and Vmax speed limiter removed.
Just curious of your settings and thoughts 👍
Srjlewis17
Re: MHD Users - Your Preferences
Post by Srjlewis17 » Wed Aug 15, 2018 6:47 pm
Stage 2+ 102 octane
Base burble - 3 seconds aggressive
Sport burble - none
Cold start delete active
Vmax removal active
I find the burbles annoying to be honest and I only ever drive the car in sport or sport + so made comfort my asbo map for when mates need heart palpitations.
2014 M135i F21 6MT AW - M4 grilles - Alcantara LCI steering wheel - M Performance shifter - BBS SR's - GazP Splitter - Forge charge pipes - Eibach Pro Kit - Armytrix turbo back with DP - MHD stage 2+ - Gladen BMW201 Extreme & Mosconi DSP
Neil-D
Post by Neil-D » Thu Aug 16, 2018 8:45 pm
Like the Comfort/Sport reversal!
Dazz4C
Post by Dazz4C » Sat Aug 18, 2018 9:54 am
I thought burble was not recommended unless you have cat delete/sport cat? I was under the impression that dumping fuel into exhaust would melt the stock cat filter.
Neil-D
Post by Neil-D » Sun Aug 19, 2018 5:54 am
First I’ve heard of that one.
Np01
Post by Np01 » Fri Aug 31, 2018 7:29 am
I am considering MHD, can anyone recommend a cheap compatible android device with otg capability, also does the software recalibrate the idrive gauges?
M135i Manual, mineral/oyster, MHD stage 1, carbon mirrors, MPE, full carbon trim, double slat grille, HK, pro Nav, Alcantara wheel, AC roof spoiler, on MPSS, Forge Motorsport Charge Pipe
shrjun
Post by shrjun » Fri Aug 31, 2018 7:54 am
read about the MHD burble problems..lots of issues with leaking valves , increased oil consumption and cat failure.
2014 F20 116i M sport manual HK audio 18" BBS CH-R Lightweight Performance front lip Storm motorwerks V2 titanium gear shift FTP motorsports intake and charge pipe Wagner Evo 2 Comp IC Remus axle back MHD S1
shrjun
Post by shrjun » Fri Aug 31, 2018 7:55 am
Any android phone with version 3.2 and above will do.I flashed MHD using a Moto G4 plus which is hardly high end.
Np01
Post by Np01 » Fri Aug 31, 2018 8:05 am
Thank you,, will look around for one, have you had any issues with MHD, has it worked well?
Srjlewis17
Post by Srjlewis17 » Fri Aug 31, 2018 8:28 am
If you're near south West London you are welcome to borrow my android tablet to flash MHD.
Np01
Post by Np01 » Fri Aug 31, 2018 8:45 am
Thanks I’m down in Bournemouth, did you use the beemergeeks cable, only all the ones on amazon say upto 2008 models, Argos are selling an Lenovo tablet for about £50, I might as well purchase one of those, thank you very much for the offer though 👍
mick.86uk
Post by mick.86uk » Fri Aug 31, 2018 3:45 pm
I used the cabe below from Amazon.
It took around 30 minutes to write the MHD flasher module.
https://www.amazon.co.uk/dp/B0779FK5NK/ ... 41_TE_dp_1
2014 F20 M135i - Manual - Glacier Silver - Pro Nav - HK - MHD Stage 1 Map
Gone:
2009 E92 335i M Sport
2004 E46 M3
2005 E87 130i M Sport
Neil-D
Post by Neil-D » Fri Aug 31, 2018 3:59 pm
ROYALTEC BMW INPA K+DCAN K DCAN... https://www.amazon.co.uk/dp/B0779FK5NK? ... pop_ma_swf
Rankie USB OTG Adapter for... https://www.amazon.co.uk/dp/B00YOX4JU6? ... pop_ma_swf
These are the cables I bought and have had no issues. Also bought a cheap android tablet for just over £30 in order o download the MHD F series App on Google Play.
I’m not surprised the Americans have had issues with oil etc if you see the way they abuse their cars.
I’ve had no problems with MHD at all.
Pre Lci EB M135i
LSD - MPE - MHD Stage 1
Np01
Post by Np01 » Fri Aug 31, 2018 4:18 pm
Thanks Mick & Neil for the cable links, am still 50/50 between MHD and Bootmod3 at the mo, have you guys been happy with the performance of the MHD tune?
Neil-D
Post by Neil-D » Fri Aug 31, 2018 4:32 pm
I only went stage 1 as my car is otherwise standard and yes, significant upgrade in power and very pleased. Insurance only went up £16 too 👌🏻
I also liked the idea of MHD as they release updates to their software and once you’ve bought a map from them the updates are free. That plus you can turn off the loud star when cold and some other settings.
Other companies may offer this but I’m not sure.
Pre Lci EB M135i
