Wiper swipe adjustment
Manufactured from end of 2011
Simonb
Re: Wiper swipe adjustment
Post by Simonb » Wed Jul 11, 2018 5:12 pm
That "off set" is only because the scuttle panel is over one way slightly.The motor will not need adjusting all you have to do now is put wiper arm back on but a notch or two down and it will solve your problem.bmw will just laugh at you if you show them that photo.
Post by Octavius » Wed Jul 11, 2018 11:14 pm
Are you sure. Look at the fixing above the wiper shaft. That’s in position and on the same panel so if the plate was out that wouldn’t align and there’s no leeway on it.
DEFECTED TO SKODA.
hhc4431441
Post by hhc4431441 » Thu Jul 12, 2018 5:41 pm
please refer Checking/adjusting contact angle of windscreen wiper arms on windscreen guild, may be can give u some help.
F20 Checking and adjusting contact angle of windscreen wiper arms on windscreen.jpg
F20 Checking and adjusting contact angle of windscreen wiper arms on windscreen.jpg (193.55 KiB) Viewed 59 times
