Lowering Question
Manufactured from end of 2011
chinskee
Lowering Question
Post by chinskee » Wed Nov 22, 2017 10:42 am
Hello, just looking for confirmation before i click buy. Will these Eibach's fit my car as it is? ie with existing shocks etc? - My car is a 116i MSport.
https://www.autodoc.co.uk/eibach/1929729
Also is it a hard process for fitting?
I've seen some links to threads on here about lowering but can't seem to find them :/. Cheers guys as always :)
13 116i MSport - Alpine White
Instagram: f21Charlie
sootyvrs
Re: Lowering Question
Post by sootyvrs » Wed Nov 22, 2017 11:24 am
These are the parts suitable for 2013 F20 116i from what I can see from this link
http://www.eibachshop.co.uk/info-part-l ... F12%2F2010
Eibach Pro-Kit Performance Spring Kit E10-20-030-01-22 seems to be the same part number so would say that it looks correct for your car..
I assume you're thinking about DIY fitting?
Garages are quoting around 3-4 hours labour to fit (around £250-300 typical)
2018 F87 BMW M2 DCT
2017 F21 BMW M140i Auto
2015 F56 Mini Cooper S Man
2013 F20 BMW M135i Auto
2010 R56 Mini Cooper D Man
2007 E87 BMW 130i Man
GeoffCollins
Post by GeoffCollins » Wed Nov 22, 2017 11:26 am
Depends if you want to do them yourself, might be worth paying someone to do it, because it's a pain in ass to do yourself!
M135i (2014 Manual) - Custom Stainless Exhaust, JB4, BMS Intake, M4 LCA, M4 Front Pads, MeisterR Coilovers, Cades Bern Wheels, Reiger Diffuser, Maxton Splitter, Double Slat Grills, M4 Mirror Caps
chinskee
Post by chinskee » Wed Nov 22, 2017 11:27 am
Thanks for that! My mate has a garage local to me where I'm thinking of going too. Is it quiet labor intensive??
Just seen your update sootyvrs. I have a garage that i can work at with a mechanic and his son, would you say it is worth it??
chinskee
Post by chinskee » Wed Nov 22, 2017 11:37 am
I can also see that it lowers it 25mm/30mm would that be the case even with the MSport suspension??
GeoffCollins
Post by GeoffCollins » Wed Nov 22, 2017 11:44 am
It lowered my M135i about 25/30, and I assume mine has M suspension :lol:
It is a long job, although some garages over quote for time, it shouldn't take more than 4 hours, the rear corners take about 20 mins each, the fronts are a bit of a pain, but for a garage should be no problem!
