Noisy heater fan
Manufactured from end of 2011
whodareswins1
Noisy heater fan
Post by whodareswins1 » Fri Dec 15, 2017 6:25 am
I can't help but think the heater fan on my F20 is a bit noisy. On the second fan setting and above it just sounds like the fan is a bit loose. The one on my E87 sounded much smoother. Is this a common problem?
F20 116i
Re: Noisy heater fan
Post by marco_polo » Fri Dec 15, 2017 8:37 am
Very early F20's suffered with leaf ingress, which sounded a bit like a motorbike apparently.
There's a revised grill/lid, iirc.
viewtopic.php?t=41699 ?
spl23
Post by spl23 » Fri Dec 15, 2017 9:55 am
I had to replace the fan in my E87 because it got unpleasantly noisy, presumably due to worn bearings - squirting Teflon lubricant into it shut it up for an hour or so, but the noise always came back. That was after 75,000 miles or so, so unlikely to be your problem unless your car has done a lot of miles?
2015 F20 LCI 125i
Barney McGrew
Post by Barney McGrew » Fri Dec 15, 2017 10:35 am
Depends what you mean by noisy / loose.
I can hear my fan as the speed increases, but you can't have complete silence when it's moving a lot of air.
Do you mean it actually rattles?
whodareswins1
Post by whodareswins1 » Fri Dec 15, 2017 8:25 pm
Just sounds like it's a bit loose. It's more than just the rush of air I can hear.
F20 116i
whodareswins1
F20 116i
whodareswins1
Post by whodareswins1 » Fri Dec 15, 2017 8:31 pm
What access to the heater fan line? Straight forward?
F20 116i
spl23
Post by spl23 » Sat Dec 16, 2017 10:25 pm
On the E87, you removed the trim at the top of the front passenger footwell (three screws and one plastic clip, and it drops out). The fan is then accessible - one screw, one plug connector and twist and it drops out. So it was pretty easy on the E87 - the F20 ought to be similar, but I've not tried it.
2015 F20 LCI 125i
whodareswins1
Post by whodareswins1 » Sun Dec 17, 2017 9:15 pm
I'd say it's more of a vibration really, through the dash. Particularly the highest setting.
F20 116i
Mr Ed
Post by Mr Ed » Mon Dec 18, 2017 7:15 pm
I had what sounds like the same problem. My fan blower would sound very loud and "grumbly" when on or close to full speed.
As has been suggested in this thread, my noise was caused by dried leaves clogging up the fan. My local dealer cleared out all the leaves and fitted a grill which should hopefully stop any more leaves getting in.
Mineral Grey 125d - Sports Auto - Heated Seats - Front/Rear Parking Sensors - Black Leather - Driver Comfort Pack - Adaptive Xenon Headlights - Interior Comfort Pack - High Beam Assist
whodareswins1
Post by whodareswins1 » Mon Dec 18, 2017 10:20 pm
Thanks for the help. Mine is just over 5 years old now so assuming it's out of warranty :(
F20 116i
Mr Ed
Post by Mr Ed » Tue Dec 19, 2017 9:57 am
My dealer charged me just over £100 for labour and the part, so worth contacting them.
