Coolant leak on turbo
Manufactured from end of 2011
chinskee
Post by chinskee » Mon May 21, 2018 7:05 pm
I was just looking at my turbo and the heat shield and I noticed all this gunk around the turbo
Any ideas
13 116i MSport - Alpine White
Instagram: f21Charlie
chinskee
Re: Coolant leak on turbo
Post by chinskee » Mon May 21, 2018 8:17 pm
Any ideas
Found out the problem! the O rings failing. seems cheap enough. could i source them from BMW direct?
11537610049
Post by marco_polo » Mon May 21, 2018 8:22 pm
chinskee
Post by chinskee » Mon May 21, 2018 8:24 pm
Thanks Marco but minimum order 10 pieces!! I’ll give my local a call tomorrow. I think you can find loads of ‘generic’ o rings on eBay is it worth it ?
Post by marco_polo » Mon May 21, 2018 8:25 pm
No, a generic o ring isn't likely to be the right grade of rubber, I'd want the correct one for the sake of £2.
I'm sure your local parts dept will be able to help.
chinskee
Post by chinskee » Mon May 21, 2018 8:27 pm
Yeah defo a shout. Glad it seems a cheap fix! Thought it was worst comes to worst new bloody turbo or something
chinskee
Post by chinskee » Tue May 22, 2018 4:01 pm
Hello Marco, i found the bolt that needs removing to get the pipes out is a 'ASA bolt' Ive heard its a female torx that does the job. You had much experience with these? I saw on the NL forums it was size 8 as well... so im guessing this will do the job. worst comes to worse im sure the people at Halfrauds could point me to the socket.
http://www.halfords.com/workshop-tools/ ... rx+sockets
Post by marco_polo » Tue May 22, 2018 4:11 pm
I would (I did) buy a full rail of E Sockets, the car is covered with them in various sizes.
Mine came from Machine Mart, iirc. Could have been screwfix....
steveespania
Post by steveespania » Tue May 22, 2018 5:04 pm
From experience, these ASA bolts can be a nightmare to remove when they are used on or close to a turbo. Make sure you get a good quality socket and a good tip is to use something like Halfords Shock and Unlock on the bolt first. It is also easy to shear the head from the bolt because of the amount of torque you can apply to this type of fastener. Might be worth getting a new bolt before starting the job.
2016 118d Advantage Navi Auto, Glacier Silver, LED Headlights, Eton b100xw door speakers.
chinskee
Post by chinskee » Tue May 22, 2018 6:47 pm
Managed to change the o rings... despite coolant erupting everywhere! All changed and time will tell of this has stopped the coolant leak!
This is what they looked liked
Post by Octavius » Tue May 22, 2018 6:53 pm
First time I’ve seen this fault on the forum. Wonder if it was a bad batch of O ring seals.
DEFECTED TO SKODA.
Post by marco_polo » Tue May 22, 2018 6:54 pm
They look in a bad way.
Make sure you refill with the correct G48 coolant, Halfords stock it, it's not dear.
chinskee
Post by chinskee » Wed May 23, 2018 10:35 am
They was in a bad way, very brittle and snapped with no force whatsoever.
Filled up the coolant with the G48 stuff and a day later doesn't appear to be any leaks etc.
Just need to clean the old gunk off when i get time and the turbo isn't boiling!
Post by marco_polo » Wed May 23, 2018 10:51 am
Good skills. :thumbs:
nathanseaman
Post by nathanseaman » Mon Jul 16, 2018 12:30 pm
I have this problem
what was the cheapest way to get these O Rings?
silly question, do you just need x2?
