N13B16A destruction
Manufactured from end of 2011
f219500
N13B16A destruction
Post by f219500 » Fri Jul 20, 2018 5:56 pm
After abusing the car for a year and half, 9 months with mods and over 20 trackdays here is what happend to my engine and turbo was ruined wastegate and metal all in turbine
63 plate 116i stage 2 remap, milltek large bore downpipe, high flow sports cat, non resonated catback, GFB DV+, piper cross airfilter,M135i Brake kit, Michelin pilot super sport x4, M4 LCA And 2017 ECU.
edbutler
Re: N13B16A destruction
Post by edbutler » Fri Jul 20, 2018 7:28 pm
So what let go first?
And whats that object in the cylinder of the 1st pic?
NISFAN
N13B16A destruction
Post by NISFAN » Fri Jul 20, 2018 7:55 pm
edbutler wrote:So what let go first?
Looks like the gudgeon pin still through the con rod, but with a missing piston.
M240i Auto
andyjhatton
Post by andyjhatton » Fri Jul 20, 2018 8:59 pm
Looks like #1 cylinder piston has failed. Fairly spectacularly.
2015 M135i, Pre-LCI, 6MT, Adaptive, Birds ARBs & Quaife LSD, M4 LCA + TS, Bilstein B14, Goodridge lines
f219500
Post by f219500 » Fri Jul 20, 2018 9:04 pm
[/quote
I think timing chain went and just ate everything in its path and yeah I think it’s gudgeon pin aswell
f219500
Post by f219500 » Fri Jul 20, 2018 9:07 pm
Yes spectacularly and it’s also the turbo cylinder so more £ but in mechanics opinion turbo was already broken as waste gate was very loose
edbutler
Post by edbutler » Fri Jul 20, 2018 9:12 pm
Good grief, yeah i see it now - helps to look on a larger screen!!
So maybe bad knock caused a shock through the piston and it snapped around the pin? The skirt exited through the block whereas the crown mangled the head...?
f219500
Post by f219500 » Fri Jul 20, 2018 9:16 pm
can only assume
jason@bwchiptune
Post by jason@bwchiptune » Sat Aug 04, 2018 8:01 am
Is there any signs of cracks on the Pistion?
Is the big end still connected and bearing in a good condition?
Did you notice and pinking or detonation ?
What was your AFRs like?
If your car was remapped did they adjust the fuelling to suit as these can run weak and need to be checked on the dyno
BW chiptune
Tuning BMWs since 1991.
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE) and Cas units.
BMW Ecu repairs.
BMW FRM repairs.
BMW remote Keys made and cut same day with or without car even if all keys lost we can supply you a key like the dealers do.
BMW key blades cut from BMW key code.
Key data fixed for non starters or when theft attempted by making key by obd.
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used).
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars.
DPF repairs fixed without the need of removal of its guts or replacement.
40% of my work is repairing the problems that are caused by other tuners remap
For more info look in our section under sponsors on this forum
0208 561 1818
07831 103030
Hayes
UB3 1BB
Click here for: BMW Remaps
Click here for: BMW Repairs
DynoDynamics rolling road testing in london & newcastle
dealers across the uk
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
f219500
Post by f219500 » Thu Nov 22, 2018 3:55 pm
BW chiptune
BW autorepairs
BMW Ecu repairs.
BMW FRM repairs.
0208 561 1818
07831 103030
Hayes
UB3 1BB
