114D Tap locations for P3 Gauge
Manufactured from end of 2011
CraigW30
Post by CraigW30 » Sat Jul 21, 2018 5:46 pm
I have searched the forum but can’t fina an answer. I recently bought a P3 multi-gauge for my 114D as since I have had it remapped I want to keep an eye on temperatures etc.
Gauge is installed in the car and is working as it should, I am getting coolant, air intake & exhaust gas temps and the revs are working aswell. Only things that aren’t working are throttle position and ignition which I believe dont work on the diesel.
Also boost isn’t working but I believe I have to tap into the map sensor wiring or use a seperate analogue boost sensor as recommended by P3 themselves.
Is there somewhere I can tap into the boost/vacuum hoses to run a hose to the boost sensor?
Also does anyone know what colour wire I could tap into to get the auto-dimmer working?
Thanks All.
Now - 2016 Valencia Orange M135i Auto - Oyster/Black Dakota - Upgraded Sport Gearbox - LED Headlights - Motech/Pipercross Air Filter - M Performance Grilles - P3 Multigauge
Old- 2013 114D Sport - Black Sapphire
