Coding Adapters - One or the other?
Manufactured from end of 2011
garysan
Post by garysan » Tue Feb 12, 2019 8:38 am
Does anyone have any thoughts on which one of these two adapters would be 'best' for some simple Bimmercode/Bimmerlink stuff?
https://www.scantool-direct.co.uk/unica ... ndows.html
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
Fanks.
Current: 2016 M135i AW, ProNav, Adaptive, Eibach Springs/TPI Spacers, F22 U/C Brace, 3D Design Bits & Pieces
Previous: 2013 E70 X5 40d Carbon Black, ProNav | 2011 E92 335d | 2004 CLK55 AMG | 2003 VW Passat V6 TDI
alanf
Re: Coding Adapters - One or the other?
Post by alanf » Tue Feb 12, 2019 8:52 am
Having read a few threads on this, the amazon module is the one that gets recommended.
I've not got one myself but that's the one I'm considering.
Have a look on ebay for the same but cheaper.
taylor354
Post by taylor354 » Tue Feb 12, 2019 12:29 pm
I'm sure there are going to be lots of responses that saying this is a one off but reading the following thread put me right off doing any coding myself with Bimmercode.
https://babybmw.net/forum/viewtopic.php?f=78&t=117089
I was thinking about some minor modifications using the app but will be holding off for now until I decide if I can live without them.
Current: Alpine White M240i - Cognac Leather
BMW_120
Post by BMW_120 » Tue Feb 12, 2019 12:35 pm
I'd personally recommend getting an BMW ENET Interface Cable instead. You get the hang of using it after the first use, and as @taylor354 said the apps are not as reliable.
2013 120dA F20 Custom Down & Straight-pipe
wenklaw
Post by wenklaw » Tue Feb 12, 2019 1:42 pm
That's terrible makes you realise that messing about yourself with coding isn't the best idea in the world.
I now want to put my M2 back to its original factory state and chuck the adaptor and app, is there anyway to do this safely?
wenklaw
Post by wenklaw » Tue Feb 12, 2019 3:01 pm
Wibbles wrote:
Tue Feb 12, 2019 2:21 pm
yep, just VO code the ECU's you changed - I can do this remotely for a small fee. you need a windows laptop and enet coding cable.
PM or email me to get the ball rolling
I don't have a non work windows laptop only a chromebook and an iMac. Shucks. I have actually coded the M2 a couple of times back to default and then coded it after ive got it back, all seems okay. I will take the risk, should be okay as nothing has changed, fingers crossed. Bimmercode and adaptor then going though as its just not worth it.
alanf
Post by alanf » Tue Feb 12, 2019 3:05 pm
Food for thought indeed!
I already have enet cable and Wibbles has already remote coded my rear PDC.
I guess what I should do is get Esys and have a look at what's involved in that.
Where's the best place to get Esys software from?
