Found a coolant leak
Manufactured from end of 2011
JPC-BMW
Post by JPC-BMW » Wed Jan 18, 2017 6:32 pm
Coolant warning light came on the wife's F20 116i today so had a look for the leak.
Fairly certain I've found it on a metal pipe which attaches to the right hand side of the engine at that point.
It is situated just under the front part of the turbo, where they air intake goes into the turbo.
Hard to describe!
It looks like it has a nut or some form of threaded end to it, so my question is how do I go about accessing it to either remove / replace or try tightening it up? Is it going to require me taking the turbo out, or can it be done with a bit of patience and the correct angle?
Or should I not even bother attempting it and take it to a mechanic?
2009 E88 118i m-sport convertible
JPC-BMW
Re: Found a coolant leak
Post by JPC-BMW » Wed Jan 18, 2017 8:34 pm
http://www.realoem.com/bmw/enUS/showpar ... Id=11_5012
It's part 11 into connector 14 on the diagram on realOEM
Mrburns903
Post by Mrburns903 » Wed Jan 25, 2017 6:07 am
I also have a leak from this pipe any advice ?
JPC-BMW
Post by JPC-BMW » Fri Jan 27, 2017 4:29 am
I haven't had a chance to look at it further yet as it appears to be a very small leak.
From looking at the diagram it seems there is a rubber washer which is probably the thing which has failed howeve cannot be sure without looking at it. It's been way too cold to fiddle about under the bonnet!
I may see if I can get access to it and check it isn't just a case of tightening it up slightly if I can reach with a spanner without having to take the turbo off!
However I feel that is unlikely to be a fix, so will likely pop it into a garage to be done.
Mrburns903
Post by Mrburns903 » Fri Jan 27, 2017 5:26 am
i shall be going into bmw today to enquire & maybe order parts.
Mrburns903
Post by Mrburns903 » Fri Jan 27, 2017 9:24 am
been to bmw this morning got the part :D £11.80 hopefully fit it later and bye bye leak :)
JPC-BMW
Post by JPC-BMW » Fri Jan 27, 2017 5:18 pm
Nice one let me know how you get on if it's straight forward I'll do it myself to
Mrburns903
Post by Mrburns903 » Thu Feb 02, 2017 6:43 am
I think i may have fixed this leak just by making sure the pipe is pushed all the way onto to connector at the engine end easy enought to do if you remove to intake pipe for a little room to move then undo the pipe clip on the rubber end and push the pipe onto its connector fully hope this helps :D
JPC-BMW
Post by JPC-BMW » Fri Feb 03, 2017 10:38 pm
Nice one thank you
whodareswins1
Post by whodareswins1 » Sat Jan 13, 2018 12:29 pm
I think I have this very same issue. Slow coolant loss and I can see fresh this area is slightly wet after a journey. And there's dried red coolant all around it. I take it I just need to clean it up and push the connector in? No twisting?
F20 116i
GarryK
Post by GarryK » Sat Jan 13, 2018 1:56 pm
Shouldn’t bmw use blue coolant?
2012 F20 mineral grey 116i Msport
whodareswins1
Post by whodareswins1 » Sat Jan 13, 2018 3:10 pm
It's the metal pipe below going into the top right hand corner of the engine. Underneath the turbo.
F20 116i
Mrburns903
Post by Mrburns903 » Sat Jan 13, 2018 3:46 pm
Deffinatley looks like the same issue i ended up have the pipe and connector replaced can turn into a job and half as the connector snapped and had to be drilled out :evil:
whodareswins1
Post by whodareswins1 » Tue Jan 16, 2018 11:52 am
Did you take yours to BMW or an indy?
F20 116i
Mrburns903
Post by Mrburns903 » Tue Jan 16, 2018 12:23 pm
Independent garage in stockport 😊
