123d Intercooler & Fuel Pump Upgrade!!!
Welcome to ecotune, home of the economy and performance remap. At ecotune we specialise in performance and economy upgrades for cars and commercial vehicles.
Moderators: Producethis, Rich196, Lambster, marco_polo, ecotuneuk
holendru
Re: 123d Intercooler & Fuel Pump Upgrade!!!
Post by holendru » Wed Jan 04, 2017 5:38 pm
Typergaz,
the 4.0 pump is the same as from 335d by realoem.com in real life it has 1 side turned. it is not a problem i can use the fuelline from a 4.0 wich is going the other side. turning the head is not possible.
i will be pleased to see the pictures.
typergaz
Post by typergaz » Thu Jan 05, 2017 7:40 pm
The pump i used both plungers were facing away from the pump input shaft much easier to work with
E82 123d 338bhp 485ftlbs Ecotune stage3
E82 123d @ 338bhp 485ftlbs Ecotune Stage3 :twisted:
typergaz
Post by typergaz » Sun Jan 08, 2017 12:34 pm
As prommised
Bregt14
Post by Bregt14 » Sun Jan 29, 2017 6:28 pm
R88ory wrote:
Scyber wrote:So parts that need to be updated for Fuel Pump upgrade
Flow control valve (The part in the fuel pump) 13517797875 (Maybe Bosch 0928400691)
(old superseded 13517804158 (09/01/2008 — 01/12/2009))
Pressure sensor in rail 13537800602 (Maybe BOSCH 0281002948)
(old part superseded 13537809130 (09/03/2007 — 10/29/2010), nonexchangeable retrospectively13537798079 (03/01/2007 — )
Fuel rail pressure regulating valve in the rail 13537801992. (Maybe BOSCH 0281002949)
(old part superseded 13537801991 (03/01/2007 — 03/01/2012))
And maybe the rail (PRESSURE ACCUMULATOR) 13537800601 (Maybe BOSCH 0445214135)
(old part superseded 13537809128 (09/03/2007 — 03/28/2014), Exchangeable retrospectively13534740787 (12/02/2010 — 09/19/2013))
Does this make any sense? Can anyone confirm these parts and which one of them is really needed?
And yes, i´m little pugnacious <3
The only one that was recomended to me, by ecotune was the flow control valve.
Beyond that i dont know what gets changed or what is interchangable. My understanding was that EcoTune carry out a modification to the HPFP and Regulator. Im personaly not going to push mine any further, (full stage two) it goes really well for a diesel and i still get 40+ on a run..
I have a 123D from 10/2007 totally stock except the performance intercooler. Do I need to replace those two parts before remap or can I keep the original?
R88ory
Post by R88ory » Mon Jan 30, 2017 6:33 am
I'd change the fuel control valve, its pretty easy to get at and will help make sure you get the best from any re map work.
BUt no you dont have to do anything, you can just get it re mapped with everything else stock. It will make a big difference!
jgalea324
Post by jgalea324 » Mon Jan 30, 2017 12:49 pm
R88ory wrote: I'd change the fuel control valve, its pretty easy to get at and will help make sure you get the best from any re map work.
Is that plug and play? What additional figures can you expect to achieve before having to swap out the rail/pump? Thanks
2010 E87 123d Msport - BMWP Body Kit, Front E9x M3 LCAs, Powerflex rear inserts, E81 chassis brace, Brembo brakes, 280 bhp/480nm torque (BMWP IC/DPF Delete) - viewtopic.php?f=19&t=70528
R88ory
Post by R88ory » Mon Jan 30, 2017 3:04 pm
Yes its a direct swap but its only any use on the earlier models as it was revised for a better design in 2010 IIRC.
About what you have got in your signature to be honest. Maybe 290 with the right map. To get any higher your into fuel pump and rail mods.
Bregt14
Post by Bregt14 » Mon Jan 30, 2017 10:02 pm
Thank you r88ory!
andrewuk1990
Post by andrewuk1990 » Sat Mar 04, 2017 2:08 pm
Hi guys, I'm currently keeping an eye out for the correct CP4.2 pump for my 123d as I am also going down this route. I'm having trouble knowing exactly which model of pump is the one I need, pressure wise and size/configuration.
I've found this CP4HS2 on eBay, can anyone confirm if this is correct?
http://www.ebay.co.uk/itm/122349503051
Thankyou :)
BMW 123d E82 - 290bhp, 600Nm @ 2.4Bar
Bosch CP4.2 Fuel Pump, FTP Charge Pipes, Mertop Racing Intercooler, Darkside DPF, M3 Wishbones, TYRANT Stage 2 camber plates, BMWP Calipers w/ EBC Y & Strongflex Subframe Poly Bushes, Bilstein B12 Pro Kit, MPS4
jgalea324
Post by jgalea324 » Tue Mar 07, 2017 9:51 am
andrewuk1990 wrote:Hi guys, I'm currently keeping an eye out for the correct CP4.2 pump for my 123d as I am also going down this route. I'm having trouble knowing exactly which model of pump is the one I need, pressure wise and size/configuration.
Thankyou :)
Let me know if you have any updates on this please :)
holendru
Post by holendru » Wed Mar 08, 2017 5:14 pm
The pump you need is 3.5d or 4.0d
jgalea324
Post by jgalea324 » Wed Mar 08, 2017 5:19 pm
holendru wrote:The pump you need is 3.5d or 4.0d
Yes but is it from the E-series or F-series cars?
holendru
Post by holendru » Wed Mar 08, 2017 5:38 pm
Mine is from a 2015 x5 4.0 F15 i also have the injectors and fuel rail and fuel lines. Stil had no time for mounting it on my Alpina D3 bi-turbo
andrewuk1990
Post by andrewuk1990 » Thu Mar 09, 2017 10:25 am
Thanks guys,
I have got the pump and rail now. It came from an X5 40d (one from the eBay add) It matches up with what I can find on real OEM. Both nossles point in direction of fuel supply/return pipes as per Gaz's so should fit ok hopefully.
Looking at fitting sometime over the next month so will post up here how it goes etc so there's more info on this in the thread.
jgalea324
Post by jgalea324 » Mon Mar 13, 2017 11:24 am
andrewuk1990 wrote:Thanks guys,
Ah bummer, that was a very good price! :) keep me updated please
Return to “Ecotune”
