Wagner Tuning 135i 335i Intercooler N54 & N55 Engine
Providing market leading CAD / FEM optimized intercooler, manifold and downpipe upgrades. Proven on road and track since 1992.
Moderators: Lambster, marco_polo, Producethis, babybmwadmin, Rich196, Mark@Wagner-Tuning
Mark@Wagner-Tuning
Post by Mark@Wagner-Tuning » Wed Sep 26, 2012 6:51 pm
Our direct swap 135i Upgrade intercooler is a direct replacement for the OEM intercooler.
It requires no cutting or modification to the car, it fits using OEM mounting points and hoses.
This intercooler is a straight swap for your OE unit and requires no more than removing the under tray and replacing the intercooler.
- Stepped High Performance Intercooler Core with Turbulators
- Size 520 x 210 x130, 11.752cm³ Volume (OEM 510x130x110mm, 7293cm³ Volume)
- CAD/FEM optimized Aluminium Cast End tanks
- Plug & Play Installation using the stock plumbing
- No cutting or bumper removal required
Image Image
Current pricing £525 inc.VAT plus shipping. Mention BabyBMW for Free UK shipping
http://www.wagner-tuning.co.uk/bmw-135i ... e-20-p.asp" onclick="window.open(this.href);return false;
Re: Wagner Tuning 135i 335i Intercooler N54 & N55 Engine
Post by marco_polo » Wed Sep 26, 2012 6:52 pm
Phoar, that's a bit sexy. :)
Mark@Wagner-Tuning
Post by Mark@Wagner-Tuning » Wed Sep 26, 2012 6:58 pm
It's a great piece of kit. One of our best sellers.
They also fit the Z4 with the N54 and N55 engines. Maybe even other models we've not tried. Get in touch if you have any questions
Meant to also mention for the 1M we do a specific version with some extra hardware to mount the cooler in a slightly different position.
This one is also £525 and can be found here http://www.wagner-tuning.co.uk/bmw-1m-e ... r-25-p.asp" onclick="window.open(this.href);return false;
Post by marco_polo » Wed Sep 26, 2012 9:03 pm
Extra cooling.
Mark@Wagner-Tuning
Post by Mark@Wagner-Tuning » Wed Sep 26, 2012 9:11 pm
L Bishop wrote:What's the benifit of fitting an upgraded intercooler?
Lower intake temps = denser air = more oxygen per volume = more power
Basically
odin
Post by odin » Thu Sep 27, 2012 7:13 am
Is there any impact on throttle response?
SL03 JOE
Post by SL03 JOE » Thu Sep 27, 2012 7:17 am
What is the bhp gain from one of these coolers?
Mark@Wagner-Tuning
Post by Mark@Wagner-Tuning » Thu Sep 27, 2012 9:54 am
There should be no noticeable impact on throttle response. The improvement in flow will more than compensate for the larger cooler volume.
Gains for just fitting our cooler should be in the region of 10-15hp. Please see attached independent dyno sheet on a stock 1M
Gains will be even bigger on a tuned car when compared to still using the factory cooler and the car will be able to run longer and harder before inlet temps start to become a problem.
Post by marco_polo » Thu Sep 27, 2012 11:18 am
Depends on how hot the turbo/s are, and the subsequent post turbo intake temperature.
Mike Roberts
Post by Mike Roberts » Fri Sep 28, 2012 12:21 pm
It's not so much an increase in power that's the benefit, more the ability to maintain that power when being pushed hard. Mine heat soaks on track, and you can feel the timing pull and reduction in oomph as the ECU tries to control the problem.
With this you get 100% of the power available, 100% of the time.
M135i more-door with added Drexler win.
Mark@Wagner-Tuning
Post by Mark@Wagner-Tuning » Fri Sep 28, 2012 12:22 pm
Mike Roberts wrote:With this you get 100% of the power available, 100% of the time.
Exactly, and a bit more power :)
Mike are you running any map or exhaust mods?
Mike Roberts
Post by Mike Roberts » Fri Sep 28, 2012 1:38 pm
No, it's bog stock apart from all the suspension mods and pending I/C install.
Mark@Wagner-Tuning
Post by Mark@Wagner-Tuning » Fri Sep 28, 2012 1:54 pm
Do you plan to tune it further?
Is yours the N54 or N55?
Mike Roberts
Post by Mike Roberts » Fri Sep 28, 2012 2:09 pm
N54
Not sure really, it's fast enough as it is, especially the rate it carries speed through bends now. That said, if I were to drive a mapped one I may change my mind.
Mark@Wagner-Tuning
Post by Mark@Wagner-Tuning » Fri Sep 28, 2012 2:13 pm
If it's fast enough for what you want then fine. I don't know so much about the BMW factory tune but I wouldn't want to do much track work with a standard VAG, not so sure about current ones but the ones I've played with most run lambda 1 and then go into overfuel to control egt.
A proper map on the car will give much improved performance and also give the engine a much safer fueling strategy. Like I said though, don't know about BMW on this.
Return to “Wagner Tuning”
