Bola CSR 18x9 at ET45 over M140i Rear Brake Calipers?
ryujinmaru
Post by ryujinmaru » Thu Jun 14, 2018 3:42 pm
Hi there, looking for some advice regarding fitment, as per the subject title.
Does anyone have or had the Bola CSRs in 18x9 ET45 configuration as their rears on their M135i/M140i?
I'm worried they may not clear the brake calipers and don't want to use spacers, which would exacerbate the already borderline poke of that set-up.
If there is no clear answer, I may look more into the Bola B6 for the partial convexity. Thanks.
Re: Bola CSR 18x9 at ET45 over M140i Rear Brake Calipers?
Post by Blind Pugh » Thu Jun 14, 2018 5:34 pm
Try using "SEARCH" in quick links.
Type in "BOLA" and select this sub-forum then see what comes up...
http://babybmw.net/forum/viewtopic.php? ... a#p1402322
ryujinmaru
Post by ryujinmaru » Thu Jun 14, 2018 5:52 pm
Thanks for the tip, but I had already searched the forums before I posted.
I had already seen that Duckson has the 8J version at ET40 all round, but that does not answer my question.
A certain Jimmer even had the 9J in ET42 on his M135i, but as he no longer seems to have a user account anymore, I could not ask him whether he had another few mm to play with between brake caliper and rotors.
Goon
Post by Goon » Sat Jun 16, 2018 7:54 pm
Why not email the Bola people yourself, I believe they are a British firm.
ryujinmaru
Post by ryujinmaru » Sat Jun 16, 2018 11:56 pm
The website was down, but I did ask them via Facebook messenger before I posted. Wanted to see if there was someone with first-hand experience for a quick answer.
Bola did get in touch a day or so later and said they had sold 18x9 ET42s and also ET45s to M135i/M140i owners "without problem". I assume without spacers, but they did not seem to want to commit. Understandable, as they can't 100% know unless they tried to fit themselves. It seems it should work anyway.
However, having measured to see what the extra poke would look like on the rear, I think I'm going with the ever-popular square 18x8 ET40 set-up instead.
Goon
Post by Goon » Sun Jun 17, 2018 5:37 am
Yes I believe the extra poke is about 12mm or so and will do no harm at all unless you are running very wide tyres on a significantly lowered suspension set up.
