M135i steering wheel clunk
JamieP
Post by JamieP » Mon Jul 16, 2018 9:52 pm
Evening all,
Just been out for a drive in my new (to me) m135i and, when parking up, noticed that the steering wheel was making a knocking sound when turning the wheel from left to right - it does it when the engine is off or on.
It sounds very loud from the outside of the car and doesn't strike me as normal...it seems to be a fairly common issue from a quick google, but just wanted to check this is definitely not normal before I phone the dealer in the morning to take a look (as i'm far from a mechanic :shock:)...
Willz135
Re: M135i steering wheel clunk
Post by Willz135 » Mon Jul 16, 2018 9:56 pm
Hi mate,
Hope your enjoying the new car, I am almost certain that what your are experiencing is a steering rack on its way out.
I recently had mine done but luckily mine was under warranty so didn’t pay a penny.
Same symptoms as you by moving the steering wheel left to right and sometimes when driving off whilst turning at slow speeds.
Hope you get it sorted soon
Will
2008 N54 135i Carbon Black with BMWP Exhaust, Wheels, Body Kit, Gearstick, Short-Shift, & Pedals
JamieP
Post by JamieP » Mon Jul 16, 2018 10:03 pm
Hi mate,
Will
Thanks for the advice - does seem to be the rack from my amateur google research, but seems a bit premature for a car that's only done 30k!
It was approved used so should be covered by warranty as well - just hope they don't bring out the "it's normal" line :starwars:
Dave2032
Post by Dave2032 » Mon Jul 16, 2018 10:56 pm
Mine wasn’t quite as easy to replicate, but a similar knock that, even from underneath, felt like a steering rack.
I ended having an O/S/F lower arm fitted under warranty. I can’t remember which lower arm.
Problem solved.
Willz135
Post by Willz135 » Mon Jul 16, 2018 10:58 pm
JamieP wrote:
Hi mate,
Will
Mine went when my car was on 15k miles! Apparently a common fault.
Will
robin_astro
Post by robin_astro » Mon Jul 16, 2018 11:13 pm
If it is the rack there is a potential cheap fix, not sure how permanent it is though
http://babybmw.net/viewtopic.php?f=74&t=110735
2104 M135i 5 door manual EB
JamieP
Post by JamieP » Tue Jul 17, 2018 7:52 am
Thanks everybody - will get it booked in today :)
RickN55
Post by RickN55 » Tue Jul 17, 2018 6:21 pm
Steering rack! Mine did this exact thing earlier this year! Cost £2500 but luckily had extended warranty :-D
Bluebird
Post by Bluebird » Wed Jul 18, 2018 12:47 pm
Need to make some wango fandango tool to be able to adjust it and tighten it. Am wondering if any lovely forum members would be willing to lend one they've made to me so I can try and eradicate my knocking. Stupid steering rack!
stevenzx10r
Post by stevenzx10r » Thu Jul 19, 2018 7:56 am
The fix above works fine for me the tool can be made chapels for about 4 quid buy some 4mm thick ally plate and some M6 bolts and nuts the dimensions to place hem are in the link above. I tightened my rack up now I have no more knocking at all and feels much better, 6000miles later still spot on with no knocks. You can do it with he car on the ground and reach through to tighten it takes about 5 mins to do.
2013 M135i, ZF 8speed Auto, 3 Door, Black Dakota Leather, Alpine White, MP Exhaust, AC Rear Spoiler, Pipercross Panel Filter, Bluespark Tuning Box, Michelin PS4’s all round.
Plans- Bilstein suspension upgrade, upgraded charge pipe.
JamieP
Post by JamieP » Thu Jul 19, 2018 8:10 pm
Cheers all - it's under warranty so taking it in, hopefully they don't try and argue it's "wear and tear" or something...
