B58 Downpipe change Guide
Williams327
Post by Williams327 » Wed Jul 18, 2018 9:11 pm
Just a quick guide for anyone thinking of replacing the downpipe on a bmw m140i m240i b58. Note i was removing my cobra 200 cell sports cat and refitting the stock downpipe.
First off get the Car jacked up in the air front and back ideally.Now underneath the car drivers side is best for access undo the two 13mm nuts holding the Cat back exhaust to the downpipe.
Imagegreen shot
Moving to the back of the car the two exhaust hangers are held on by 13mm nuts these need removing, note the exhaust will lower slightly as its no longer supported. Now lever with your hands on both exhaust tips the cat back away from the downpipe by pulling and twisting away from the front of the car. This will seperate the two.
Imagejpg host
Open the bonnet, firstly remove the engine cover pulling up around the edges. Now the airbox needs to be removed, unplug the maf sensor and using a 6mm socket undo the jubiliee connecting the airbox to the hose. Seperate the two. The airbox itself is on rubber bungs to remove simpley pull upwards may take a little force.
Now you have access to the cat, unplug both lambda sensors in the engine this way its easier to remove them when the cat is off the car.
Using a 13mm socket undo the Vband which holds the Cat to the turbo.
Now on a stock downpipe there are two 13mm nuts which hold the cat to the chassis these need removing
Imagewindows screenshot tool
Its now free and you can remove by lowering it down and out underneath the car. Now you can remove both lambda sensors using a 22mm spanner
Fitting your new Decat/Sports Cat is the reverse procedure. Overall fairly easy job for anyone half competent with a set of spanners
:D :D
M140i 3 door Auto
Mods - Dervtech, JB4, LSD, underbody brace, BCS catback, Decat, AFE intake, auto id mirrors>diffuser, kerscher splitter, carbon spoiler, Mp skirts>blades>grills, OZ ultraleggeras, H&R -25mm, M4 pads, braided lines
MrPocketRocket
Post by MrPocketRocket » Wed Jul 18, 2018 9:24 pm
Excellent work mate! Thanks for sharing. Definitely helps especially with images as a reference point.
Admins - Can this please be added as a Sticky
Cheers!
Last edited by MrPocketRocket on Wed Jul 18, 2018 9:24 pm, edited 1 time in total.
BMW M140i - 5 Door - Coral Red Leather - Mineral Grey - M Performance Exhaust (Carbon Tips) - M Performance Side Decals - M Performance Grills - Front Silencer Delete - Carbon Front Splitter/Side Skirts/Side Mirrors/Rear Diffuser/Rear Spoiler
Williams327
Re: B58 Downpipe change Guide
Post by Williams327 » Wed Jul 18, 2018 9:42 pm
Admins - Can this please be added as a Stickey
Cheers!
No worries hopefully inspires a few more driveway mechanics :lol:
M140i 3 door Auto
MrArthur
Post by MrArthur » Wed Jul 18, 2018 11:51 pm
This guide is just great! Thank you very mutch!
Now make it a sticky!
Alpine White BMW M140i 5-door, MPE with carbon tips and front oval muffler delete, PiperCross filter, BlueSpark, Dragy GPS, ZF 8-speed, adaptive, HK, and mutch mutch more, witout moonroof
and79
Post by and79 » Thu Jul 19, 2018 6:17 am
Good work!
BigWill
Post by BigWill » Thu Jul 19, 2018 8:48 am
Great write up!
MY18 EB M140i Aus Spec LCI-2 Auto
Alcantara interior, M Performance Steering Wheel
EdButcher
Post by EdButcher » Fri Jul 20, 2018 9:01 am
How do people get around MOT time with a decat?
M135i Pre LCI - Estoril Blue F20 - MPE - H&R 25mm - M2 style Black Grill - darklines
Williams327
Post by Williams327 » Fri Jul 20, 2018 11:35 am
Me personally I’d refit the stock cat takes about an hour start to finish.
Many just palm the mot guys hands with gold :lol:
M140i 3 door Auto
EdButcher
Post by EdButcher » Fri Jul 20, 2018 4:18 pm
I see! Haha I may just get my MPE modified for the sound I want rather than faffing with it then ... I know my luck. No MOT tester would touch it haha
Mr Kirk
Post by Mr Kirk » Sat Jul 21, 2018 1:00 pm
Removing your sports cat you say?
Williams327
Post by Williams327 » Sat Jul 21, 2018 8:55 pm
Sold it, got a decat on the way ready for a ecu map and hopefully meth
M140i 3 door Auto
Andrew1810
Post by Andrew1810 » Tue Oct 16, 2018 10:17 am
Why does the original cat, and a Cobra decat have the mounting plate to the chassis, yet the sports cat does not ?
kriszty
Post by kriszty » Thu Oct 25, 2018 8:29 am
Just curious ,,,
But how did the Cobra 200 cell performed ? , where you happy with the downpipe and was the added sound noticeable ?
thanks, Kriszty
Williams327
Post by Williams327 » Thu Oct 25, 2018 4:13 pm
Just curious ,,,
thanks, Kriszty
Was a good downpipe, sound increase is very similar to a decat tbh
M140i 3 door Auto
kriszty
Post by kriszty » Thu Oct 25, 2018 5:00 pm
thanks, i,m planning to buy one for my m240i :wavey: :wavey: no issues with installing this DP , i,m running JB4 on Map 1 , after i hope Map 2 will run perfect together with this cat..
greets,
