Birds or Motech
Torquey
Re: Birds or Motech
Post by Torquey »
I have the Birds system and love it, having them fit the Quaife LSD next month as well. 😀
2015 M135i lci. M4 lca’s. Birds 🦅 B series suspension. Quaife lsd. Underbody brace. BW Chiptune remap.
Connar92
Re: Birds or Motech
Post by Connar92 »
JonD wrote:Birds!
Motech fit generic sping’s (no disrespect to the forum sponsor), birds have developed their own setup specifically for uk roads.
Arnt they both Eibachs though in the birds and motech kit? Image
Glacier silver M235i (full aero kit with MPE) - 🦅 Birds B2 dynamics kit (suspension and Quaife LSD) - M4 LCA and TS - powerflex subframe inserts - 5mm front 15mm rear tpi spacers with orbit grey 436m’s
Connar92
Re: Birds or Motech
Post by Connar92 »
Torquey wrote:I have the Birds system and love it, having them fit the Quaife LSD next month as well. Image
Whats yours a 135/140/235/240?
Connar92
Re: Birds or Motech
Post by Connar92 »
Connar92 wrote:
JonD wrote:Birds!
When i spoke to Mike with regards to the motech spring rates he explained that eibach wouldn’t disclose the adaptations with their springs ie spring rates etc however that their springs had been compressed over the standard eibach pros. So their stuff is essentially just an “eibach b12 kit” thats £100/150 more.
But the cynic in me would then think that the same rules would apply with birds. Ie eibach kept their cards close to their chest when it came to certain aspects of springs. However when i spoke to Kevin he explained that these kits were bespoke made for birds and not a generic spring. However Eibach may produce a spring that has the same fitment but different rate ie f30 etc. I dont know. Thats what id like to know exactly the differences. If that was the case though all that leaves would be a re valved/ softer B6 damper to work better with rougher surfaces.
JonD
Re: Birds or Motech
Post by JonD »
When I spoke with birds they use a stiffer spring rate, made by Eibach, and their dampers have different rates from the standard off the shelf bilstien, whole package is to their spec not a just a combination off the shelf parts.
Torquey
Re: Birds or Motech
Post by Torquey »
Connar92 wrote:
Sun Feb 10, 2019 6:53 am
M135i, it’s in my signature at the bottom of my post 👍
Re: Birds or Motech
Post by marco_polo »
Whatever springs you happen to pick (makes very little difference in this case OP), make sure you get some better quality dampers too.
OPOGTS
Re: Birds or Motech
Post by OPOGTS »
To start with why not try a simple and v cheap upgrade to eibach springs? That simple change utterly transformed my car to the extent I can’t see value for money or need to do the dampers too. It was a HUGE improvement, transformed the car (which lets be honest is highly suspect when pushing on in standard form)
981 Cayman GTS
Outgoing: DMS m135i + Eibachs
Incoming: Litchfield m140i + LSD + Eibachs
OPOGTS
Re: Birds or Motech
Post by OPOGTS »
Torquey wrote:
Sun Feb 10, 2019 6:11 am
Interested you have birds and the M4 LCAs. When I spoke to Birds he recommended against the LCAs? Did you do separately, how do you find them?
981 Cayman GTS
Torquey
Re: Birds or Motech
Post by Torquey »
Hi, I spoke to Birds and they didn’t really think m4 lca’s would make a difference , and they recommended fitting spacers on the front.But after reading so many positive reviews on here I had them fitted anyway. It’s made a huge difference on how the front just digs in in the corners and turns in so much better. I had the underbody brace fitted also which helps stiffen up the rear. When I get the lsd fitted I think it should handle even better.
Re: Birds or Motech
Did they really say adding a degree of negative camber wouldn't make any difference?! :shock:
Their credibility has just plummeted in my estimations.
Torquey
Re: Birds or Motech
Post by Torquey »
They said if there suspension man Kevin Weaver didn’t suggest it it didn’t need it, they also said they would be happy to be proved wrong.
Connar92
Birds or Motech
Post by Connar92 »
Torquey wrote:
Sun Feb 10, 2019 12:48 pm
Thats the thing ive never heard of kevin weaver. I cant be the only one? Image
Edit: James Weaver even! ImageImageImage
racey1979
Re: Birds or Motech
Post by racey1979 »
Connar92 wrote:
Sun Feb 10, 2019 5:22 pm
Thats the thing ive never heard of kevin weaver. I cant be the only one? 😂
Hes not called Kevin Weaver, he's called James Weaver...........
https://en.m.wikipedia.org/wiki/James_W ... ng_driver)
F22 67 M240i MG, Coral, Birds B2, MP Kit, HK, Pro Media
E91 59 335d Space Grey Emaps 350 BHP 710 nm (hers)
E46 02 325ti Compact - Sold
E46 01 330ci Coupe - Sold
Renault Clio 16 Valve
Citroen AX GTI - Saxo VTS Engined Money Pit - “Gone” :wink:
Spoof
Re: Birds or Motech
Post by Spoof »
I'm not sure how you chaps get the M-lites to understeer. All mine wants to do is oversteer.
Maybe some trail braking guidance would be adviasable before spending money on LCA's? Driven in this manner, even on the track, I've not had the slightest whiff of understeer on factory cambers.
As for the diff, you'll probably find you've introduce more understeer now, so the LCA's might be a good thing.
