Max size tyres for...
kalv
Post by kalv » Mon Feb 11, 2019 7:57 pm
Hi,
Any thoughts on what the maximum width/profile tyre i can go with on the following:
8.5x19 ET43
9.5x19 ET50
Assuming the safe/trusted bet is 225/35/19 and 255/30/19... just wondering if I could get a wider tyre considering the rims are bigger (in both ways) and is there any real advantage on going wider (apart from extra grip)? Downside I guess will be added expense?
Luckily the MPS4s are available in the 225/35 & 255/30 - I haven't checked any other sizes.
Many thanks as always.
Re: Max size tyres for...
Post by marco_polo » Mon Feb 11, 2019 8:05 pm
You could certainly go for a 235/35/19 front if you fancied less nasty understeer? You might even squeak a 245/30 on the front, they'd be quite close to the strut though, try before you buy if possible.
A 265/30/19 should just fit on the back if you wanted more traction?
GMballistic
Post by GMballistic » Mon Feb 11, 2019 8:13 pm
...and is there any real advantage on going wider (apart from extra grip)? Downside I guess will be added expense?
Yes extra grip but imho it also looks better.
I definitely believe these cars are "under tyred" from the factory for the most part. :wink:
Not much difference in price in it either between say a 225 and a 245 or a 255 and a 265.
MPS4 is a very good choice of tyre too btw. It's what I have and they're fantastic.
2012 Alpine White F20 M135i
kalv
Post by kalv » Tue Feb 12, 2019 10:33 am
Thanks.. I currently run the MPS4 on my 436M alloys in standard 18" sizes and they're great.. the MPS4s are available in 19" so am thinking 235/35/19 on the front and stick to the 265/30/19 on the rear.
This option is actually £40 cheaper than the 225/255 tyres - Lol
kalv
Post by kalv » Tue Feb 12, 2019 11:31 am
I spoke/asked the supplier of the wheels and his response is:
"You can try to use 235 and 265, however I can ensure you that there will be rubbing issues. For the 235/35 in the front, it might be possible that it even does not clear the suspension on the inner side. On the rear you would have to drive a very high chamber angle and do fender rolling in order to avoid rubbing issues. We highly recommend 225 and 255 tires, especially if you will be using Michelin Pilot 4S tires.
Wonder if my local tyre garage will be friendly enough to try a wider tyre before buying???
Post by marco_polo » Tue Feb 12, 2019 11:34 am
They should do, if they have them in stock.
kalv
Post by kalv » Tue Feb 12, 2019 4:34 pm
Local garage can’t “mock-up”... and I cant order 8 tyres and send 4 back..?
Would BMW Technical be any help..?
Post by marco_polo » Tue Feb 12, 2019 4:36 pm
Doubt it!
kalv
Post by kalv » Tue Feb 12, 2019 5:08 pm
Doubt it!
play it safe then.. will also help with re-sale in future??
Post by marco_polo » Tue Feb 12, 2019 5:58 pm
This is what a 265mm tyre looks like at ET50: viewtopic.php?f=19&t=58392&start=60#p797318
Up to you though, go for the super-stretched safe fitment if you want to play it cautiously.
kalv
Post by kalv » Tue Feb 12, 2019 6:08 pm
Will the fact that my rims will be 19” in size and also 9.5 wide on the rear (same offset ET50 as the 18x9 in the example) make it just as compatible?
Post by marco_polo » Tue Feb 12, 2019 6:16 pm
The tyre walls will be slightly more angled in your case (1/4") but the centreline of the tread will obviously be in the exact same position.
As you're so nervous, go for the skinny stretched tyres this time, see how much room there is around them for next time. If you drive fairly hard you'll be through them in a few months.
kalv
Post by kalv » Tue Feb 12, 2019 9:32 pm
https://youtu.be/uLx3hWmkYCs
Should help show/explain the wheels... I can’t seem the view the tyre sizes or find out who’s car it is to ask what’s on this M240i
