compression test
quickH
compression test
Post by quickH »
Hello all,
Can i do a compression test by pulling all connectors from the ignition coil and then trying to start? I don't want to fry my ECU
Locoblade
Re: compression test
Post by Locoblade »
The chances of a modern engine being low on compression are extremely small, how come do you want to do a compression test?
Chapscrap
Post by Chapscrap »
OP has an oil consumption problem, see a
previous thread.
Current: June 2019 M140 auto Shadow, Sunset Orange/Oyster/Adaptive, + other options.
Gone: Too numerous to list, but I am quite old.😉
Locoblade
Post by Locoblade »
Ah ok, fair enough, much more likely to be something like the turbo seals than bore wear though I'd have thought.
Autosri
Post by Autosri »
Yeah you should be good just unplugging the coil packs and spinning the engine over
It will throw a load of engine codes so aslong as you have something to clear them after
Good luck and hopefully it comes back alright
quickH
Post by quickH »
Locoblade wrote:
Thu Mar 26, 2020 7:37 am
Have had the intercooler off and it was clean. It consumeert about 1l every 1500km so if it was the turbo i guess it would have been dripping oil out of the IC
Thanks for the replies. Anybody knows the fuelpump fuse number/location?
JohnsM135i
Post by JohnsM135i »
Not necessarily, oil can go both ways ie into the exhaust side/hot side as well as the compressor side.
M240i :D
M135i loved it, but gone
quickH
Post by quickH »
JohnsM135i wrote:
Sun Mar 29, 2020 8:46 pm
might pop off the downpipe than to check the shaft play and see if there is anything strange to see
