WOW, I did not know that...
un1eash
Re: WOW, I did not know that...
Post by un1eash » Sat Jul 14, 2018 2:51 pm
Menace wrote:
Sat Jul 14, 2018 9:29 am
un1eash wrote:
Fri Jul 13, 2018 1:04 pm
RSR182 wrote:
Fri Jul 13, 2018 12:05 pm
It inflates the side bolsters
Correct but they don't inflate, just move in and out on a step motor.
Pretty sure they do in fact inflate - what makes you think they are ‘on a step motor’?
Assumed they were the same as the F10 5 series, I did not know that they were different on the F20. To be honest I've set them once and never touched the button since.
OldSkool
Post by OldSkool » Sat Jul 14, 2018 5:16 pm
scov1984 wrote:Underneath the dashboard near to the glovebox, in the corner.... right underneath.... there is an extra 12v socket. I did not know that until recently.
My 2015 LCI doesn't have this.
Alpine White F20 M135i LCI, Auto
Indium Grey 2018 Golf GTI
moulin12
Post by moulin12 » Sat Jul 14, 2018 5:26 pm
Do you have a small driver's side storage compartment? Around that time there was an option called extended storage, and as I recall included the driver side storage compartment, the two useless rear door pockets, a boot net and an additional 12v socket.
F22 M240i 8AT
GeeDee
Post by GeeDee » Sat Jul 14, 2018 10:19 pm
FWIW I have it on my '14 model which has the central access into the boot but no nets. I don't recall any "useless" rear door pockets - not something I've noticed.
Happybiker
Post by Happybiker » Sun Jul 15, 2018 6:16 pm
Not something that's of much use but interesting anyway, I have a towbar mounted bike rack on mine, with the electrics connected the coast function doesn't work in eco pro. I thought mine was broken until I tested it again in normal mode without the bike rack.
Bluebird
Something I didn't know...
Post by Bluebird » Mon Jul 16, 2018 5:31 pm
Just popped out to the car after it's been sat in the sun all day, nuclear hot inside, got in to start it up and put the A/C on and closed the door behind me. I went back inside and thought I wonder if I can lock it while it's warming up (cooling down the cabin) and it just so happens you can! That's bloody handy! :spotman:
Tricky401
Re: Something I didn't know...
Post by Tricky401 » Mon Jul 16, 2018 10:17 pm
Can do the same in winter to help defrost the screen and warm the seats up. Always leave my disklok still on in this scenario just incase
Menace
Post by Menace » Tue Jul 17, 2018 4:48 am
What car exactly do you have? I’m pretty certain it was / is standard on all M135i at the time
65 plate F20 M135i / MG / auto / well spec’ed with: Eibach Pro's / F21 tension strut / black grilles, splitter, side blades & diffuser / full de-badge
joeclay
Post by joeclay » Tue Jul 17, 2018 8:12 am
Does the horn not sound on the 135 to notify you engine is running when you lock?
On mine I have the choice of pissing the neighbours off or leaving it unlocked
M140i SE MG AT - Adaptive - Pro Media - Under Body Brace - MPE - AutoID bits
robin_astro
Post by robin_astro » Tue Jul 17, 2018 10:58 am
Not on mine.
2104 M135i 5 door manual EB
Bluebird
Post by Bluebird » Tue Jul 17, 2018 11:04 am
Not on mine.
Nor mine
RSR182
Post by RSR182 » Tue Jul 17, 2018 11:36 am
66 plate M140i horn sounds, can confirm!
Clio 182
M140i
Village_Idiot
Post by Village_Idiot » Tue Jul 17, 2018 11:44 am
Interesting- I have the same age and model car, but mine doesn't sound the horn when locked with the engine running. Certainly did it enough times last winter so I think I'd have noticed!
2016 M140i Estoril Blue - Manual - HK - Comfort Pack
2012 Focus ST-2 Mk3
2009 Golf TDI 110
joeclay
Post by joeclay » Tue Jul 17, 2018 11:48 am
Another update from the m135i to m140i then. Presume it's for security reasons, but with the 6 cylinder rumble its impossible to not realise it's running when you get out/lock it!
Although imagine it could be coded out
Mr Kirk
Post by Mr Kirk » Tue Jul 17, 2018 11:48 am
This is something I want to find out, not that I have found out yet!
Recently when I get in the car, the car shown on the black panel display has an orange outline to it.
Is this to tell me it’s hot inside or something?
