A rival for Carly? Bimmercode
RickN55
Re: A rival for Carly? Bimmercode
Post by RickN55 » Thu Jun 14, 2018 12:14 pm
Falltrack wrote:
Thu Jun 14, 2018 6:47 am
Just ordered the vgate wifi version, thanks to mikesmith2939 and RickN55 :)
Enjoy playing around with it! It is amazing what you can do on it :D
Now - F21 2013 Alpine White M135i Auto (Sun protection package, Driver comfort package, Bum Warmers, Black Panel, HK, High Gloss shadowline Finish, M Performance grills, rear spoiler and fins)
Before - Focus ST Stage 1, Astra 1.8 SRi, Clio 1.2
mikesmith2939
Post by mikesmith2939 » Mon Jul 02, 2018 4:58 pm
Although I have an F30 xdrive I thought this may be of use to others.
I coded the Enhanced bluetooth following the instructions sent by Stephan and all went well, however it will not connect to the audio on my iPhone X.
It will connect to my iPad Pro without issue, so I assume the issue is with the Iphone.
mikesmith2939
Post by mikesmith2939 » Tue Jul 03, 2018 4:57 pm
An update.
The head unit did a reset on it's own for some reason.
However I removed the phone from the bluetooth reconnected and now it works as it should.
joncoyle87
Post by joncoyle87 » Fri Jul 20, 2018 3:27 pm
Just an update as I’ve not seen anyone with the same year / model posting on this.
June 2018, Business Nav, iDrive6
Just followed the printed / highlighted instructions from page 16 to enable advanced Bluetooth/ office.
Worked first time, now have 2 x phones connected(tested incoming and outgoing on both) and contact pictures. With the first phone connected I selected the second phone and it gives the option to either connect, or connect secondary. Once selected the phone has a small 2 next to it.
I couldn’t see any office menu, but sent myself a text and it came straight through and was visible in the notification centre, clicking it also reads it out loud.
If I click the “i” next to the text message it displays “no sender phone number was transmitted, therefore no answer is possible”
Anyone know if there’s a way around that? No a big issue as I’m able to send messages via siri using the voice command on the steering wheel
ninja_geezer
Post by ninja_geezer » Sat Aug 04, 2018 5:31 pm
simple question for when my new car arrives M240i,can bimmercode clear fault codes as well as change stuff on the car like my OBDeleven can on the VAG group cars or do i need something else as well.
Android user.
Tubes
Post by Tubes » Sat Aug 04, 2018 6:41 pm
Android user.
No. There is another ‘Bimmer’ app, can’t recall from the top of my head but that offers that functionality. If you are an android user justvuse Torque/Pro.
shrjun
Post by shrjun » Sun Aug 05, 2018 7:52 am
so i coded the digital speedometer via bimmercode but it doesn't appear on the dash! emailed Stephan ( the app creator ) and he says that I need to ' switch through the board computer options to set it ' - what does this mean :?:
2014 F20 116i M sport manual HK audio 18" BBS CH-R Lightweight Performance front lip Storm motorwerks V2 titanium gear shift FTP motorsports intake and charge pipe Wagner Evo 2 Comp IC MHD S1
RogerF
Post by RogerF » Sun Aug 05, 2018 7:59 am
Use the top button on the left hand side indicator stalk to cycle through the display I would guess ?
'63 plate 125d M Sport
shrjun
Post by shrjun » Sun Aug 05, 2018 2:12 pm
figured it out.Thank you
GingerOtter
Post by GingerOtter » Wed Aug 08, 2018 11:07 pm
[/quote]
Called Bimmerlink. Reads fault codes, clears codes, open exhaust valve and turn off/on ASD if you have it.
66 M140i, Auto, F20, Sapphire Black, ACS Sports Suspension, Focal audio upgrade
17 LR Discovery HSE Lux
Previous
RR Evoque Dyn Lux
Z4 35is M DCT (2X)
Seat Ibiza FR
ninja_geezer
Post by ninja_geezer » Thu Aug 09, 2018 9:00 am
[/quote]
ok is bimmerlink better than bimmercode ? may as well just have one .
i have torque already .
Current: 2018 M240i Auto, Alpine white,Coral Red Leather,Heated Seats ,Reversing Camera,Pro Media,Harman Kardon
Previous: 2016 Golf R DSG
JackW
Post by JackW » Thu Aug 09, 2018 10:43 am
I've got an F20 with reverse parking sensors.
Any way to code them so when the cars in neutral you can turn the parking sensor beeps off?
Im sick of reversing into a parking space leaving the engine on and having to listen to the beep of the sensors - and you cant turn it off in the cabin until you press engine stop
RogerF
Post by RogerF » Thu Aug 09, 2018 2:48 pm
Mine go off when I select P, or by pressing the button ? (leaving the engine running)
JackW
Post by JackW » Thu Aug 09, 2018 6:54 pm
But do you have front sensors too? The P button only seems to be present with BMWs will all round arming sensors 😩
JackW
Post by JackW » Fri Aug 10, 2018 9:43 am
Bought the Bluetooth OBD (as the bimmercode website said it was better at the minute) and coded a few things in last night.
Locking beep
Digital Speedo
Rear DRL
AutoStart/Stop to remember last setting
Rear wiper frequency after wash
Seatbelt beep/warning light off
Anyone in the North East want anything coded give me a shout 8)
