New to this
bfi2906
New to this
Post by bfi2906 » Wed Sep 05, 2018 12:41 am
I've never tried "coding" a car before, so my apologies for the simplicity of my questions.
I have a 2018 M140 Auto - Is BimmerCode the best option to use?
I've had a look at BimmerCode in Demo mode, and from what I can see, there are a lot of changes that can be made in the "normal" mode, with the screens in English & easily understandable. But in "Expert" mode, it seems to be largely abbreviations / derivations of English, with German mixed in.
Is it the same in the actual app you buy? And if so, is there a "translation chart" somewhere, so the purpose of the settings can be understood?
Thanks in advance.
Wibbles
Re: New to this
Post by Wibbles » Wed Sep 05, 2018 8:24 am
I would not use Bimmercode - it's a great idea but it can brick ECU's - I've had to repair many.
Loads of members use it but the fact there is no hard connection between phone & car there is always a danger the connection will drop.
BR Diagnostics & Retrofits
Apple Carplay - ONLY £89 - BabyBMW Special offer!
FULL SCREEN CARPLAY NOW AVAILABLE!
BRD on Facebook
bfi2906
Re: New to this
Post by bfi2906 » Wed Sep 05, 2018 8:29 am
Thanks for the reply.
If not BimmerCode, what do you recommend?
And, if it drops the connection, what happens? Most modern software will pick up at an auto-save point from Cache (or some other mechanism), when the connection is re-established.
Wibbles
Re: New to this
Post by Wibbles » Wed Sep 05, 2018 7:10 pm
It doesn't, it causes the ECU to code to default values that it would have it was bought new, causing all sorts of problems.
I had a customer over the weekend with an iDrive that had this issue, basically it didn't work until I fixed it.
I would use esys or get a professional.
BRD on Facebook
jono400
Re: New to this
Post by jono400 » Wed Sep 05, 2018 8:51 pm
What do you charge for a remote coding for just the headlight voltage check and what cable would be required for a bmw e88 ?
BMW 120 D msport convertible / E88
* Still looking for a set off Depos v2 *
Wibbles
Re: New to this
Post by Wibbles » Thu Sep 06, 2018 9:34 pm
£30 for a basic remote session.
Get a cable from www.cable-shack.co.uk
BRD on Facebook
jono400
Re: New to this
Post by jono400 » Thu Sep 06, 2018 9:51 pm
Okay thanks for that decent price. bit pricey on the cable for what could be a one time use but appreciatte so is bmw labour rates !!
Wibbles
Re: New to this
Post by Wibbles » Fri Sep 07, 2018 10:56 am
I don't sell the cables, so can't set the prices, sorry.
BRD on Facebook
jono400
Re: New to this
Post by jono400 » Fri Sep 07, 2018 11:15 am
No appreciate that mate I know you don't was just saying that your labour charges were very fare but for a one off coding and required cable it works out fairly expensive but again as mentioned previously appreciate bmw labour rates are not cheap either !
Wibbles
Re: New to this
Post by Wibbles » Fri Sep 07, 2018 11:22 am
i can loan out a cable for a small fee & as long as you return it I will refund the deposit.
BRD on Facebook
jono400
Re: New to this
Post by jono400 » Fri Sep 07, 2018 6:25 pm
No probs mate nice idea. Will give you a shout when I get a bit money together . Thanks again.
John
P.s Any idea what coding options are available on the E88 ? . Remote softop ?
Wibbles
Re: New to this
Post by Wibbles » Tue Sep 11, 2018 9:24 am
John
I have a list of coding options.
Remote soft top is only possible if your car has Comfort Access as an option.
BRD on Facebook
jono400
Re: New to this
Post by jono400 » Tue Sep 11, 2018 2:49 pm
Okay thanks any chance off listing the options for the e88 and how would I know if my car has the comfort access option fitted ?
Wibbles
Re: New to this
Post by Wibbles » Thu Sep 13, 2018 1:34 pm
jono400 wrote:Okay thanks any chance off listing the options for the e88 and how would I know if my car has the comfort access option fitted ?
Put your VIN into www.bmwvin.com
BRD on Facebook
jono400
Re: New to this
Post by jono400 » Thu Sep 13, 2018 6:44 pm
Okay thanks.
