M140i Active Sound Coded - Updated with Guide
Re: M140i Active Sound Coded - Updated with Guide
Post by marco_polo » Tue Aug 15, 2017 8:11 am
I use ESYS
OneTwenty
Post by OneTwenty » Tue Aug 15, 2017 10:00 am
jassi wrote:
Tue Aug 15, 2017 5:34 am
So if ASD is the only thing I want to code :roll: , bimmercode is the wrong app to do it. Is Carly any better or the recommendation is esys method in this thread.
There are so many good things to code I don't know why you would just want to do ASD alone.
Even just small things like the speed threshold for when you can fold in the mirrors etc are worth the money alone imo.
66 M240i Coupe, MW, Coral, Auto, Vis/Comfort/Sun, Pro Nav, Heated Wheel/Seats, Elec Seats/Lumbar, Adaptive, Camera/Park Assist, Speed Lim, HK, Split/Fold, WiFi/EBT, F/M
09 320d E91, Silver, Pro Nav, BT, Auto L/W, Ht/Leather, SPG, Cruise
jassi
Post by jassi » Tue Aug 15, 2017 11:06 am
^^ agreed i know once i have access to a library of things I can code, I am sure I will start tinkering around. However I have barely run-in my m140i at this point and ASD was the only immediate thing I could think of addressing. Its sounding like use esys for ASD and then bimmercode for all the other goodness?
Aussie M140i 5 door with mpe and underbody brace, warranty friendly
Aussie NZ M135i/M140i/M235i/M240i Owners Facebook Group https://www.facebook.com/groups/248993522276877/
OneTwenty
Post by OneTwenty » Tue Aug 15, 2017 11:22 am
ASD coding works with Bimmercode, providing you don't mess about with the engine type/model range type and/or the audio power class. - When I did that and changed to N55/F22 and none HK sound that's when it messed up for me.
But it's reversible so nothing to worry about.
jassi
Post by jassi » Tue Aug 15, 2017 10:16 pm
^^ if I just want to increase the ASD volume and not mess with engine and power class, does that require going into expert mode? I already have HK audio. So looking for the easiest path on this :D
OneTwenty
Post by OneTwenty » Tue Aug 15, 2017 10:24 pm
In Bimmercode you just click expert mode, then go into 3000 active sound design, then just change the power class to either sl04 or tl05 in the drop down. Then go back and press code and all done.
It doesn't make much difference in volume though imo.
jassi
Post by jassi » Wed Aug 16, 2017 1:09 am
^^ perfect thanks!
GeeDee
Post by GeeDee » Fri Sep 15, 2017 4:02 pm
I manged to code my ASD Off last night along with all the other sound I discovered this morning. :lol:
Back on now thank goodness....
I'll have to go through this thread in detail.
Crazy_Raesy
Post by Crazy_Raesy » Wed Oct 04, 2017 12:17 am
Any updates on this topic? I had an M Performance Exhaust put onto my M140i SE from the day of collection in the hope it would improve the acoustics, which it has done marginally but no where near as good as my M135i.
All I want to do is change the volume of the ASD to max in the hope of improving the drama inside the cabin when pushing on. Is Bimmercode safe to do this alone & if so how simple is it? What if something goes wrong, how easy is it to rectify?
Alternatively is there anyone in the Essex area or surrounding counties that is proficient in this and could do for me? Happy to pay!
sootyvrs
Post by sootyvrs » Mon Oct 16, 2017 4:37 pm
Tried to do this today but when I connected to the car, I could see the connection via VIN (which I assume says it's connected OK) and I can select it but there's nothing to select in the Target so the "Connect" button is greyed out..
The part I'm at is at the screen shot below if it helps but this is when it's not connected (I can see the VIN of my car when it's connected up)
Any ideas?
2018 F87 BMW M2 DCT
2017 F21 BMW M140i Auto
2015 F56 Mini Cooper S Man
2013 F20 BMW M135i Auto
2010 R56 Mini Cooper D Man
2007 E87 BMW 130i Man
Post by marco_polo » Mon Oct 16, 2017 4:44 pm
Any ideas?
Do you have a valid 'token' sorted?
sootyvrs
Post by sootyvrs » Mon Oct 16, 2017 5:45 pm
Followed the instructions step by step so assume I have a token.. Is there a way i can check?
Edit: Just looked back on what I did and I think I have the token as it asked me to put in a pin which I put in 1234 as I remember that bit
2018 F87 BMW M2 DCT
tuaho
Post by tuaho » Sun May 20, 2018 12:45 pm
Hi there, I posted the same question in a new thread somewhere else but nobody seem to be able to help. Found this thread, I hope someone may be able to provide some insight!
So I took my F20 2013 M135i to a coder the other day who helped installed a 6WA and folding wing mirrors. Unfortunately he (and his friend) also decided to mess around with my ASD and it stopped working! When I looked into the module with Bimmercode it showed that "motor" was set to S63B44 and "baureihe" was set to F086. I know that those are the wrong models and might have affected the ASD so I switched them back to what I think should be right for my car (F20/21 and N55B30) but the ASD still isn't working!
The coder didn't seem to know how to fix this and when I asked him he said the module had been reset to factory. I find that hard to believe as the engine and car model numbers were wrong. The other settings in the module currently are:
AudioSystem - Stereo
Leistungsklasse - OL
Competition paket - No
Laendervariante - ECE
Baustand - Above 07/2013
I have played around with it by changing Leistungklasse to all the different settings which I believe is volume. Even tried turning on and off competition paket. Only thing I never touched was Laendervariente which I believe is region since the other options are China and USA. Does anybody know what all the default values are? Or anybody with esys nearby who can help reset / recode the entire module back to factory?
downshift
Post by downshift » Fri Feb 08, 2019 6:47 am
Hi guys,
According to the ASD levels here:
-> SL appears to be the highest level.
But when I look in de bimmercode app:
->TL appears to be the highest level.
So my question, is SL or TL the highest ASD level :D
Wibbles
Post by Wibbles » Mon Feb 11, 2019 4:54 pm
They obviously don't know what they are doing - on early firmware you could set the engine to a different version, say the S55 from an M4 but in later firmware BMW stopped that ability.
If you code the wrong engine type the ASD stops working - it needs to be VO coded back to factory & the volume turned up.
BR Diagnostics & Retrofits
Apple Carplay - ONLY £89 - BabyBMW Special offer!
FULL SCREEN CARPLAY NOW AVAILABLE!
BRD on Facebook
