Mileage now showing 999999 after coding
robsaboy
Re: Mileage now showing 999999 after coding
Post by robsaboy » Sat Jan 19, 2019 3:17 pm
Where are you based - someone could maybe lend you a cable.
M140i, Mineral Grey
Post by Nottsknots » Sat Jan 19, 2019 3:38 pm
Enet looks a bit like scart at one end, but its definately not one. Something like
https://www.amazon.co.uk/dp/B01F8J2E3S/ ... 5958130302
Disconnecting the battery wont screw anything; you will have to reset the clock, but dont worry about it (just be careful to take the lead off quickly and avoid too much sparking - make sure you dont have any high loads on whilst doing the disconnect - fan off, radio off, doors shut so there arent too many lights on etc. - unlikely you can do any damage, but sensible precautions reduce the already small risk to negligible).
Not long now until the end of May...
Wibbles
Post by Wibbles » Mon Jan 21, 2019 11:19 am
Nottsknots wrote:
Sat Jan 19, 2019 3:35 am
Kerr wrote:
Fri Jan 18, 2019 8:42 pm
That tamper dot is going to cause you hassle in the future if it can't be removed.
Aw, dont take away F32Daves only hope :)
I dont think thats what Wibbles meant about not being able to “code it out”. If I understand this right, you cant switch the dot off in isolation, but you can correct the VIN in the other modules, so its all in sync, then the dot goes away on its own. Its only there because the software has spotted an inconsistency. Its not fixed there permanently.
Even in the worse case stated by Wibbles, BMW will have the encryption algorithm, somwhilst it might be a trip to the dealers, and a whole bunch of explaining to assure its not been done for underhand purposes, its possible to correct it. Start with remote coding and see if that works
It would seem like it's coded default values and probably wiped the CAFD which is why the cloks are lit up like a christmas tree.
The mileage being 999999 is more worrying as that usually requires the EEPROM to be removed from the board on the clocks and erased - however if the clocks are newer than 03/2016 the mileage is encypted and is much harder to wipe out (I don't have the tools for that currently as it is a big investment for something I don't use much)
BR Diagnostics & Retrofits
BRD on Facebook
Post by Nottsknots » Mon Jan 21, 2019 3:50 pm
Thanks - I like to learn something new every day :D . Not that I think I’ll be needing to know that, but at least I know YOU know, so thats enough for me.
“ ‘ang on a minute, I know a man who can!” (Think Michael Caine)
Post by Octavius » Mon Jan 21, 2019 7:26 pm
The mileage will be recorded on the key ?
Glacier Silver 320d M Sport.
dailydoggy
Post by dailydoggy » Mon Jan 21, 2019 7:57 pm
Tis a sobering harsh lesson indeed in dicking about wildly with iffy 3 party apps with zero knowledge..
340BHP, manual shift ,£140 tax!!Got wood! :drive:
F32Dave
Post by F32Dave » Wed Jan 23, 2019 6:41 pm
Based in Birmingham, also it’s a 16 plate.
Dizmond
Post by Dizmond » Mon Mar 11, 2019 11:55 am
Hey F32Dave, did you have any joy getting this sorted in the end? Just curious.. :)
2016 BMW M135i LCI Auto - Estoril Blue (Current)
2003 BMW 530d Aegean
2002 BMW 530d
2002 Smart ForTwo
1995 Mercedes C200
1991 Honda Prelude 2.2i VTEC
1983 Porsche 924
1995 Vauxhall Cavalier 1.8 LSi
1985 Ford Sierra 1.6
1984 Vauxhall Cavalier 1.4l
Connar92
Post by Connar92 » Mon Mar 11, 2019 8:25 pm
This is quite a scary read considering the amount of damage that can be done coding simple things.
Are all these app coding devices all the same? I.e bimmercode, carly etc etc.
Post by Octavius » Mon Mar 11, 2019 8:52 pm
If I need any coding in the future I will be contacting Wibbles.
I’ve coded with Carly in the past but have read too many threads about problems caused by this type of app.
Wibbles
Post by Wibbles » Wed Mar 13, 2019 10:48 am
Good to see you are back in the BMW fold :)
BRD on Facebook
Post by Octavius » Wed Mar 13, 2019 6:00 pm
Thanks Craig. No doubt I will be in touch soon.
Ry_B
Post by Ry_B » Sun Mar 17, 2019 9:21 pm
Scary what can happen. OP - did you manage to get this sorted? Hope you did :shock:
M235i in mineral white - Auto. Extremely well specced :mrgreen:
