Bimmercode for cruise control.
Moderators: babybmwadmin, Producethis, marco_polo, Lambster, Rich196
StuM84
Post by StuM84 »
Hello,
Can the Bimmercode app be used to code retro fitted cruise control on a 2017 116d auto?
Thanks.
Marc_Coding
Re: Bimmercode for cruise control.
Post by Marc_Coding »
Hello, no Bimmercode is useless for retrofits
You need to use E-SYS
Haldon
Post by Haldon »
It can be used.
Esys is better though, as bimmercode will most likely be gone after the dealer updates software on your car.
Marc_Coding
Haldon wrote: Fri Mar 08, 2019 5:34 am It can be used.
Where is the Cruise Control retrofit/activation menu in Bimmercode?
Haldon
Post by Haldon »
Marc_Coding wrote: Fri Mar 08, 2019 10:30 am
Expert mode
Robestelle
Post by Robestelle »
Hi
Is there anyone in the East Yorkshire area that could code my cruise control to 125i coupe
Not brilliant with software packages
Cheers rob
zsoltti
Post by zsoltti »
Hello, I have to revive this post, since nobody has answered the questions the others have asked.
Exaclty where can I find bimmercode cruise control retrofit activation at? Expert mode that was the last answer But that is not much of an answer!
Thanks in advance!
*-jester-*
Post by *-jester-* »
It's not straightforward in Bimmercode, there isn't a "retrofit" option as such, instead it's a case of changing a number of coding settings. I've never tried it because I already have cruise control fitted but in theory it should be doable.
Pato Elosua
Post by Pato Elosua »
Also interested in this! I've got the buttons on my steering wheel, only need to code now. I've been having a hard time running the Token Generator for the Esys, so would appreciate a bimmercode solution.
Johag
Post by Johag »
Pato Elosua wrote: Sat Apr 04, 2020 2:22 am Also interested in this! I've got the buttons on my steering wheel, only need to code now. I've been having a hard time running the Token Generator for the Esys, so would appreciate a bimmercode solution.
You can use esys without the launcher for vo coding cruise control.launcher is only required for fdl coding.
Pato Elosua
Johag wrote: Tue Apr 07, 2020 3:10 pm
Thanks man, got someone to help me via remote. Now works like a champ 🙌🏻
piovo
Post by piovo »
could you post how it was done? through bimmercode?
Medium
Post by Medium »
I don't think you can edit the Vehicle Order using Bimmercode, even in expert mode can you (it will let you view the VO tree, but not edit)? All expert mode seems to do is show you the actual code values on the FDL tree, rather then giving you a simplified UI. The VO is what you need to alter to retrofit cruise control, and then apply the modified data to the application control modules.
All that Bimmercode let's you do is change the value of individual FDL elements as has been said above; you don't need to change these to retrofit CC, so unless there's an area of Bimmercode I haven't found, you can't use it to add CC.
ESYS is free to downland and will let you alter the VO without the paid launcher.
