M2 speedo dials in in F20 retrofitting coding Help
lukehadjigeorgiou
Post by lukehadjigeorgiou » Tue Dec 12, 2017 1:36 pm
Hello, I have a 2013 M135i and i wanted to change my speedo dials to the M2 F87 dial.
I need help on esys how to code in the M2 dials.
I know it can be done because I've seen it on https://www.youtube.com/watch?v=zxhlpJnoMys
Not much else info on the internet for this subject.
Wibbles
Re: M2 speedo dials in in F20 retrofitting coding Help
Post by Wibbles » Mon Dec 18, 2017 10:56 am
Coding should be no different to coding any other Kombi.
does your car already have 6WA?
If not, add the MOST Loop, add 6WA to VO and code the headunit, refresh SVT & code Kombi.
new Kombi must have VIN & Mileage erased. If date of Kombi manufacture is > 03/2016 then mileage cannot be erased so the Kombi must have < miles than your car or you will get a red tamper dot, although the Kombi will still function.
HTH
BR Diagnostics & Retrofits
Apple Carplay - ONLY £89 - BabyBMW Special offer!
BRD on Facebook
lukehadjigeorgiou
Post by lukehadjigeorgiou » Wed Dec 20, 2017 4:07 am
Hi. Yes it already has the 6WA. The full black display speedo dials.
Would the millage to auto correct with the key? I always thought the the millage was recorded on the key.
Thanks for the reply
lukehadjigeorgiou
Post by lukehadjigeorgiou » Wed Dec 20, 2017 4:08 am
The M2 dials I have are made in 2015
Wibbles
Post by Wibbles » Thu Dec 21, 2017 2:17 pm
The mileage will correct once installed and coded. The issue is you have to have the Kombi virginised - the VIN needs to be erased or it will have a tamper dot.
Mileage is stored in multiple modules.
BRD on Facebook
Return to “Coding/Software”
