Page 1 of 1
Coding Wifi
Posted: Thu Dec 14, 2017 10:06 am
by andybell007
Hi All
I have a 67 plate 125D Shadow Edition with Pro Nav and I'm wondering if it's possible to code Wifi?
The end goal is I'm trying to enable screen mirroring from Android.
Andy
Re: Coding Wifi
Posted: Thu Dec 14, 2017 4:32 pm
by Matthaus
Is the wifi not just a hot spot that uses the sim in the car at some stupidly expensive rate?
Re: Coding Wifi
Posted: Sat Dec 16, 2017 10:35 pm
by andybell007
From the little information I could find there appeared to be an android cast/screen mirror option if you have WiFi hotspot which makes sense as you'd need WiFi for that to work. Anyone know the answer?
Re: Coding Wifi
Posted: Mon Dec 18, 2017 10:49 am
by Wibbles
Android screen mirroring can easily be coded. to be of any use you would also need to have Video in Motion coded to be able to use the screen mirroring on the move.
I can do both remotely or in person if you're near Tyneside.
PM or Email for prices.
Re: Coding Wifi
Posted: Mon Dec 18, 2017 10:11 pm
by Matthaus
Does this need ID6 or does it work with ID5?
Re: Coding Wifi
Posted: Thu Dec 21, 2017 2:13 pm
by Wibbles
Works with either - id5 & 6 are just different graphical interfaces.
Re: Coding Wifi
Posted: Thu Jan 11, 2018 11:18 am
by Matthaus
Hi Wibbles
Do you know if there is a guide anywhere on how to make this work? I have WIFI etc already and I wonder if it should just work or the dealer can turn it on?
Info seems very thin on the ground as to how it works or how you enable it
Re: Coding Wifi
Posted: Sat Jan 13, 2018 11:36 am
by Wibbles
Hi Wibbles
Video in Motion on ID5 or screen mirroring?
Re: Coding Wifi
Posted: Sun Jan 14, 2018 11:19 am
by Matthaus
Hi Wibbles
Screen mirroring - I have since found a video of where it should be in ID5 - but I dont seem to get that option. Is it defo available for all M240s?
I wonder if I should speak to BMW to see how to get it enabled but I fear they dont have a clue what I am talking about :(
Re: Coding Wifi
Posted: Sun Jan 14, 2018 2:54 pm
by H17YD_L
Re: Coding Wifi
Posted: Sun Jan 14, 2018 4:41 pm
by Wibbles
Hi Wibbles
a BMW dealer will give you a blank stare and say "it's not possible"
It is possible, either code it yourself or I can do it remotely for a fee.
Re: Coding Wifi
Posted: Sun Jan 14, 2018 4:59 pm
by Matthaus
Can it be done with bimmercode? If not what does it Need?
Re: Coding Wifi
Posted: Sun Jan 14, 2018 9:28 pm
by Wibbles
I believe it can be done via Bimmercode. I don't have any experience with that app but there are others on this forum that can help.
Re: Coding Wifi
Posted: Sun Jan 14, 2018 9:29 pm
by Matthaus
Thanks. Appreciated.
