OBD iPhone Apps
R8JimBob88
OBD iPhone Apps
Post by R8JimBob88 » Thu Aug 27, 2015 10:35 pm
Evening gents,
I'm looking for an app on my iPhone (5c) that I can use the access the OBD info in my Pre FL E87 130i.
I'm not particularly interested in coding but would like to view fault codes and realtime diagnostics such as coolant temp etc.
Is there anything out there compatible with the Pre FL E87 that doesn't require a cable and computer?
E87 Pre Facelift 130i
Re: OBD iPhone Apps
Post by marco_polo » Thu Aug 27, 2015 10:39 pm
With an iPhone you'll need a WiFi Dongle to connect, Bluetooth won't work.
Mine's an F20, but I use an iCar Vgate ELM327 dongle, and an app called DashCommand.
Reads and clears error codes, and has all the gauges I need.
Re: OBD iPhone Apps
Post by Twenny » Thu Aug 27, 2015 11:29 pm
That's it Dash Command!!! Forgot about that app cheers MP
R8JimBob88
Re: OBD iPhone Apps
Post by R8JimBob88 » Fri Aug 28, 2015 2:47 pm
Cheers guys,
Downloaded the app and borrowed a wifi Elm 327 from a colleague. Will give it a whirl tonight
ESvensson
Re: OBD iPhone Apps
Post by ESvensson » Mon May 14, 2018 10:32 pm
Is still Dash command the app to buy?
m140i xdrive in order
Re: OBD iPhone Apps
Post by marco_polo » Mon May 14, 2018 10:46 pm
Not sure, I still use it when I want to see additional gauges & info.
ESvensson
Re: OBD iPhone Apps
Post by ESvensson » Tue May 15, 2018 3:46 pm
Ok, then ill buy it :)
Thanks for answer!
Return to “Coding/Software”
