A rival for Carly? Bimmercode
Plantjuk
Re: A rival for Carly? Bimmercode
Post by Plantjuk » Sat Sep 02, 2017 1:29 pm
Have you started the engine?
M135i LCI, mineral grey, auto, bus nav, power folding mirrors, heated seats, coral red leather and front & rear pdc, performance grills, BMS exhaust tips, enhanced Bluetooth, office function and 8.8" screen coded via bimmercode app.
Mr Kirk
Post by Mr Kirk » Sat Sep 02, 2017 1:30 pm
Plantjuk wrote:Have you started the engine?
Tried with engine off and running.
Plantjuk
Post by Plantjuk » Sat Sep 02, 2017 1:31 pm
Could be a dodgy dongle
Mr Kirk
Post by Mr Kirk » Sat Sep 02, 2017 1:32 pm
Plantjuk wrote:Could be a dodgy dongle
When I first plug it in, all the lights flash once. Then just the red battery light stays on.
Johnnyo
Post by Johnnyo » Sat Sep 02, 2017 3:31 pm
I had this with mine yesterday (first time use) - turn off, removed, locked car and tried again and it worked... wasn't sure what the problem was but worked okay...
Does your phone detect the dongle wifi?
2017 Petrol - many galloping horses.. Intergalactic miles....
2014 Dirty White 120d sport auto - brilliant but gone to help save the planet from diesel....
Mr Kirk
Post by Mr Kirk » Sat Sep 02, 2017 3:33 pm
Johnnyo wrote:I had this with mine yesterday (first time use) - turn off, removed, locked car and tried again and it worked... wasn't sure what the problem was but worked okay...
No. Doesn't detect wifi or Bluetooth.
What order did you plug in/turn ignition on/turn engine on/try to connect?
Johnnyo
Post by Johnnyo » Sat Sep 02, 2017 3:37 pm
the attempt that worked for me was having the engine running and then plugging in the dongle. i had turned off wifi on my iPhone and then turned that back on once i had inserted the dongle. it found the gate wifi but took a few goes to get it to connect, then opened up bimmercode and it worked okay (disconcerting when the engine turns off and instruments reset!!).
Mr Kirk
Post by Mr Kirk » Sat Sep 02, 2017 4:11 pm
Just tried it again in every order I could think of and still nothing.
Johnnyo
Post by Johnnyo » Sat Sep 02, 2017 4:38 pm
I did mine again - took few attempts on dongle - yellow triangle/exclamation mark on wifi screen on phone. Tried connecting with BimmerCode and worked after a few tries...
Mr Kirk
Post by Mr Kirk » Sat Sep 16, 2017 9:57 am
I must be doing something wrong with this.
I've now got a second dongle. Bluetooth only though.
Press the power button and nothing happens. Again.
nb67
Post by nb67 » Sat Sep 16, 2017 10:11 am
Turn Wi-Fi on your mobile as it's Wi-Fi enabled.
EB 240i Convertible.
Mr Kirk
Post by Mr Kirk » Sat Sep 16, 2017 10:12 am
It's not a wifi adaptor. Bluetooth only.
nb67
Post by nb67 » Sat Sep 16, 2017 10:17 am
Ah, I see you did say that.
My VGate adaptor will only work via Wi-Fi which I believe is the preferred/only method of using them is it not or am I wrong with that?
I'm sure more knowledgeable users will expand on this.
Plantjuk
Post by Plantjuk » Sat Sep 16, 2017 10:39 am
The fact that with carly you can only use a wifi adapter when using an iOS device I'd say that as bimmercode is an iOS only app then you'll need a wifi adapter to connect to the car not a Bluetooth.
Mr Kirk
Post by Mr Kirk » Sat Sep 16, 2017 10:51 am
Plantjuk wrote:The fact that with carly you can only use a wifi adapter when using an iOS device I'd say that as bimmercode is an iOS only app then you'll need a wifi adapter to connect to the car not a Bluetooth.
That may be the case.
Still doesn't help solve the issue of the dongle not connecting via Bluetooth.
Return to “Coding/Software”
