A rival for Carly? Bimmercode
DannyBDJ
Re: A rival for Carly? Bimmercode
Post by DannyBDJ » Sun Jan 28, 2018 11:10 am
Anyone know if it’s possible to code folding mirrors on door lock without holding down the button?
Black Pre-LCI F20 M135i
Tubes
Post by Tubes » Sun Jan 28, 2018 11:14 am
Yes. It’s a basic setting in the FEM.
DannyBDJ
Post by DannyBDJ » Sun Jan 28, 2018 11:20 am
Great thanks I’ll have a look today. Sick of having to hold the button down
Post by Twenny » Sun Jan 28, 2018 11:22 am
i531m wrote:Ive used bimmercode changed a few things
folding/unfolding mirrors over 30mph
led light under handles when reversing
m display start up
my question is i havent touched the seatbelt warning , and i cant remember if the standard setting beeped upon start up ,until you buckled up?
as mine now doesnt, only has a light on the dash which goes out when buckled, i just get 1 chim when un buckling if driving
cheers for replys
Doesn’t it beep after a minute of the engine started and belt not clipped in?
P-Torqued 266bhp-BMWP exhaust+Strut+intake+skirts+grilles---Rieger diffuser-Darklines-retrofit cruise control-M135i front brakes-VMR v710-Eibach ARB
i531m
Post by i531m » Sun Jan 28, 2018 11:27 am
Im not sure id have to check, so it doesnt beep right after start up, normally ?
Post by Twenny » Sun Jan 28, 2018 11:28 am
DannyBDJ wrote:Great thanks I’ll have a look today. Sick of having to hold the button down
Set it to 0 seconds and it’ll close on lock.
My only warning with this is unlikely to happen but it has happened.
If you lock your car and it freezes overnight, when you unlock, if it’s frozen solid you can break the wing mirror motor or the whole mechanism can break.
Unlikely but just thought I’d point it out.
I re code mine to long push of fob during winter months (when I change to my winters) just in case.
Tubes
Post by Tubes » Sun Jan 28, 2018 10:06 pm
m display start up
cheers for replys
It’s based upon distance before it chimes. 200m iirc.
i531m
Post by i531m » Sun Jan 28, 2018 10:19 pm
ok cheers for the replys , i dont think anything has changed just couldnt remember how it was in the first place
DannyBDJ
Post by DannyBDJ » Mon Mar 05, 2018 6:59 pm
Anyone know how to code the black label display to stay on daytime colours (white) permanently?
dk250
Post by dk250 » Fri Mar 30, 2018 4:11 pm
Successfully coded some basics this afternoon on my m140 via bimmercode and vgate 2
seat belt beeps off
stop start off default
door led on in reverse
rear drl enabled
alarm beep
drl lights on off via idrive
Red sports displays
m performance idrive boot screen
Now for some bank holiday reading on what else can be done .
lower
Post by lower » Tue Apr 03, 2018 12:33 pm
Hi all,
I'm new here but have through pretty much all 47 pages in this thread.
In some of the early posts there was a comment made that the Bimmercode app can break the satnav in cars with Idrive4. Can anyone confirm if this is correct?
I have a 2016 M2 that i want to turn off active sound in and have the radio turn off when i open the car door.
Shumbalicious
Post by Shumbalicious » Tue Apr 03, 2018 3:06 pm
Managed to code:
Bluetooth streaming (no more wires!)
Radio off on door opening
Window interrupt off on door opening
LED door lights on on reverse
Start/Stop off by default
Massive thanks to the advice on this thread :D
Justchris17
Post by Justchris17 » Sun Apr 08, 2018 7:21 pm
Have many people coded a new battery using bimmercode? Can you code none bmw batteries fine also?
2010 N55 135i, Manual , Metallic sapphire black
Ckpearce91
Post by Ckpearce91 » Sun Apr 08, 2018 8:45 pm
Has anyone coded the parking sensors so that the front ones are on all the time? I can’t believe that they don’t come on till I either put the car in reverse or press a button
Wibbles
Post by Wibbles » Mon Apr 09, 2018 1:37 pm
Not possible - Auto PDC is a function on new G series cars and the active tourer models IIRC.
BR Diagnostics & Retrofits
BRD on Facebook
Return to “Coding/Software”
