1st set showing our recommendation when mated to the OEM M140i/240i rear silencer and the second set showing the DDE which is recommended when fitting with the MPE.
Nige
Without DDE
With DDE
The following are a selection from our 'Hall of Shame' where customers have had a 'Custom chop' install.
Some of the worst fabrication I've seen - one even had the pipe welded (if you can call it that onto the downpipe/cat
Thanks for looking
Please call 01744 610244 for more details
Nige
