225xe Roof Rails - not standard equipment!!
RedlineDrifter
Re: 225xe Roof Rails - not standard equipment!!
Post by RedlineDrifter » Sun Sep 09, 2018 11:08 am
MarkySpark wrote:I suppose it depends how tightly you tighten the straps, how heavy the bikes are, potential shocks from bumps/damage in the road etc.
More than likely. If you are a bit ham fisted for sure you run the risk of causing damage (even if using factory fitted kit).
Salesmen (& women) will only be thinkin about how to avoid you returning as a disgruntled customer, so will forever air on the side of caution. Plus I’m sure they have a nice mark up on OE aftermarket stuff.
After a year of real life use, and about 4-5k miles across Europe with my Saris rack carrying two specialized mountain bikes, I can honestly say that the plastic spoiler remains unmarked and appears to be more than strong enough for the job.
F21 M135I LCI
- "Sideways is the way forwards"
225xeBikeMan
Post by 225xeBikeMan » Mon Sep 10, 2018 8:20 am
Thanks for the replies. It fits the car so I just need to know whether it will be safe. I’ve emailed Saris to see if they can advise anything.
sid_james
Post by sid_james » Mon Nov 19, 2018 10:28 pm
annoyingly I missed out on the roof bars too. "don't they all come with that?"
I've has a 520 tourer for the last five years!
Tom-Con
Post by Tom-Con » Sat Nov 24, 2018 7:56 pm
RedlineDrifter wrote:
Mon May 29, 2017 4:04 pm
I requested a quote from the dealer to retrofit which came out at an eye watering £1000!
Wow, £1k seems insane! I've just bought a 2014 Active Tourer, and would love to retro fit some roof rails. Anyone else either had this done or quoted for the work? There is a body coloured strip along the line of the roof rails, and I had assumed (hoped) it would be a case of removing this and bolting on the rails...
Babaa
Post by Babaa » Sun Nov 25, 2018 7:30 pm
Hi Tom-Con,
Yep - was in the same boat and didn't want to spend £1,000 to use the actual rail / channel areas, but ended up when getting a Thule roof rack / roof box from Halfords, finding out that for about £40 more there is a set of fixing brackets that just clamp down under the lip where the top of the door seal goes, and work ok.
Admittedly it was a bit of time with the guys there not wanting to over tighten and possibly damage the door surround skin, but still tightening a bit at a time to make sure it is on solidly, but with it in place, has been totally problem free.
I suppose the one downside is that when we don't use the actual roof box, I can't be bothered to take the roof rails off having seen how long they took to measure exactly how far apart they should be & carefully tighten them, but we got aero designed ones which don't seem to add any noise at all on motorways, and although I guess maybe they might impact mpg a little, it most gets use to do 1-2 miles at a time around 30mph areas, so all works well for what we need.
Cheers -- Babaa
2018 m140i SE
2015 220i Active Tourer
2013 m135i (now gone)
bnorris
Post by bnorris » Mon Jan 14, 2019 10:06 am
Does anybody transport there bikes in the back of the 225xe?
I'm looking at getting one but unsure if I'll get a 29er in the back with seats down. I normally take the front wheel off anyway but does anyone have a length from the back of the front seats to the boot?
TIA
