M135i (LCI) best wheel offset?
LondonMark
Post by LondonMark » Thu Jan 04, 2018 1:51 pm
Hi everyone, I have a question! :? :?
I've seen all the great photos of your cars with the 20/25mm Motech springs, and the 12/15mm spacers. I want to get this look too, but the insurance hike for adding the spacers is +£130, (the springs not so much extra), so I've decided to buy new wheels with an offset that will give me the same look I would get by adding wheel spacers. After looking at tons of wheels, the ones I like the best have a fitment of: Front 8J ET38, Rear 9J ET42. Using an offset calculator, based on the OEM wheels, the new fronts extend and extra 13mm, and the new rears extend and extra 23mm.
Does anyone know if:
1,These will fit ok without any problem?
2, if they do, will they give the look/stance that I'm after?
Cheers :D
Link to wheels (not sure yet whether to go for 18" or 19")
http://www.bmautosport.co.uk/showroom/p ... 154_25_204
PS: Let me know if I've posted this in the wrong section! :D
Re: M135i (LCI) best wheel offset?
Post by Blind Pugh » Thu Jan 04, 2018 2:17 pm
Mark,
You could consider OE F3x alloys which are wider and have lower numerical offsets give more stance, compared to OE F2x alloys.
Photo below is of my old car on H&R sport springs and F8x LCA's up front with OE style 397 alloys [18" x 8" x et34mm all round] with OE MPSS 225/245 tyres F&R
BP
m135i HR sport F8x LCA 3.jpg (162.96 KiB) Viewed 529 times
Post by marco_polo » Thu Jan 04, 2018 2:22 pm
Cheers :D
They will fit, and have the extremely stanced/aggressive look you're after.
Ezzra
Post by Ezzra » Thu Jan 04, 2018 2:22 pm
From an engineering perspective spacers are the work of Satan.
Post by Blind Pugh » Thu Jan 04, 2018 2:29 pm
Agree 100%
Post by Blind Pugh » Thu Jan 04, 2018 2:30 pm
Mark,
BP
More photos of style 397's on an LCI car on stock suspension.....viewtopic.php?f=74&t=94540&start=1110#p1330312
LondonMark
Post by LondonMark » Thu Jan 04, 2018 6:34 pm
Thank you all for your replies, they're all very helpful. :spotman:
Blind Pugh - The 397's look great, but the new price is out of my budget, and even used on Ebay are quite pricey, plus I'm a bit unsure about buying used wheels.
Cheers, Mark :P
Paul CS
Post by Paul CS » Thu Jan 04, 2018 10:07 pm
Agree 100%
Another 100%.
M140i MR Shadow Edition. MP springs. Under frame brace.
mtechtone
Post by mtechtone » Thu Jan 04, 2018 11:41 pm
Can someone please explain why it’s better to run wheels with a lower offset rather than equivalent spacers? :)
HEAVYD
Post by HEAVYD » Fri Jan 05, 2018 2:09 pm
Paul CS wrote:
Agree 100%
Another 100%.
Remember these chop shop garage spacers!
Ezzra
Post by Ezzra » Fri Jan 05, 2018 2:32 pm
"Better" is not the word. "Less worse" is more accurate. Specifically to your question. If you really, really must change the offset, different wheels gives one less clamping surface for torque to be transmitted via the wheels to the road.
Remember that the bolts do not transmit torque, they merely hold two surfaces together.
Post by marco_polo » Fri Jan 05, 2018 2:44 pm
Agreed.
Wheels with silly offsets still muck up the scrub radius, so I wouldn't fit front wheels like that personally. It's not so much of an issue on the rear, from a Geo point of view.
Post by Blind Pugh » Fri Jan 05, 2018 2:54 pm
Cheers, Mark :P
I have set that came off my car 8"/8.5" in ferric grey - used but in good condition no dents/buckles or repairs. Provided yr budget is realistic, perhaps PM me an offer ???
As you are London based too, suggest you come and have look 1st hand.
mtechtone
Post by mtechtone » Fri Jan 05, 2018 11:26 pm
So are we saying, for example, running wheels with 10mm lower offset or running a 10mm spacer would have an identical effect on scrub radius and the associated handling characteristics?
Does introducing another clamping surface create a weak link, as such?
Just trying to understand why spacers are frowned upon, thanks :)
Post by Blind Pugh » Fri Jan 05, 2018 11:39 pm
Check with yr insurer - cost of changing wheels v cost of adding spacers to yr OEM wheels......
