A rival for Carly? Bimmercode
R88
Re: A rival for Carly? Bimmercode
Post by R88 » Sun Jan 21, 2018 3:16 am
shifty_dave wrote:
Wed Nov 29, 2017 7:30 pm
Quick tip for Android users to save a few pennies when buying Bimmercode - You can pick up a £25 Google Play voucher for £24.30 through https://www.zeek.me/, and if you go to Zeek via Topcashback then you can get a bit more back. Feel free to register with my referral link! https://www.topcashback.co.uk/ref/shifty_dave
Top tip. Thank you!
They are now £23 for £25 voucher! Saving 8% before cashback.
Tubes
Post by Tubes » Mon Jan 22, 2018 12:59 pm
R88 wrote:
Sun Jan 21, 2018 12:34 am
Is there any meaningful difference between the bluetooth version compared to the wifi other than the fact that they communicate through different means?
Not sure how valid this is anymore but previously Android devices connected via BT and iOS via WIFI.
R88
Post by R88 » Mon Jan 22, 2018 4:54 pm
The latest model seems to support both, which is why I'm asking. Have bit the bullet on the WiFi version as I think as WiFi should have faster transfer rate.
Will report back if it works haha!
https://www.amazon.co.uk/gp/product/B06 ... UTF8&psc=1
Post by Twenny » Mon Jan 22, 2018 5:59 pm
I think the iCar2 is preferable as it has an on/off switch which should avoid anything going into sleep mode and bricking your ECU.
R88
Post by R88 » Mon Jan 22, 2018 8:47 pm
Can someone confirm this because the BimmerCode site links to the latest versions.
http://www.bimmercodeapp.com/
Hopefully the latest app has some safeguards to keep the device awake.
Alex_m135i
Post by Alex_m135i » Wed Jan 24, 2018 6:23 pm
First post here.
Just wondering what the code is for Bluetooth music streaming. Still can’t believe it doesn’t have built in Bluetooth music streaming
2014 m135i
smind
Post by smind » Thu Jan 25, 2018 8:01 pm
Apologies if this is a noob question but interested in getting a display up for speed, oil temp etc.
Is it possible to fit a WiFi obd adapter on an m240i or does
The location near the door jam get in the way?
Tubes
Post by Tubes » Thu Jan 25, 2018 8:10 pm
It will fit but the flap wouldn’t close. However I wouldn’t recommend leaving it plugged in all the time. Security has changed a lot with the vehicles and the OBD port is on an ignition live but it’s a good practice.
i531m
Post by i531m » Sun Jan 28, 2018 10:46 am
Ive used bimmercode changed a few things
folding/unfolding mirrors over 30mph
led light under handles when reversing
m display start up
my question is i havent touched the seatbelt warning , and i cant remember if the standard setting beeped upon start up ,until you buckled up?
as mine now doesnt, only has a light on the dash which goes out when buckled, i just get 1 chim when un buckling if driving
cheers for replys
DannyBDJ
Post by DannyBDJ » Sun Jan 28, 2018 11:10 am
Anyone know if it’s possible to code folding mirrors on door lock without holding down the button?
Black Pre-LCI F20 M135i
Tubes
Post by Tubes » Sun Jan 28, 2018 11:14 am
Yes. It’s a basic setting in the FEM.
DannyBDJ
Post by DannyBDJ » Sun Jan 28, 2018 11:20 am
Great thanks I’ll have a look today. Sick of having to hold the button down
Post by Twenny » Sun Jan 28, 2018 11:22 am
i531m wrote:Ive used bimmercode changed a few things
m display start up
cheers for replys
Doesn’t it beep after a minute of the engine started and belt not clipped in?
i531m
Post by i531m » Sun Jan 28, 2018 11:27 am
Im not sure id have to check, so it doesnt beep right after start up, normally ?
Post by Twenny » Sun Jan 28, 2018 11:28 am
DannyBDJ wrote:Great thanks I’ll have a look today. Sick of having to hold the button down
Set it to 0 seconds and it’ll close on lock.
My only warning with this is unlikely to happen but it has happened.
If you lock your car and it freezes overnight, when you unlock, if it’s frozen solid you can break the wing mirror motor or the whole mechanism can break.
Unlikely but just thought I’d point it out.
I re code mine to long push of fob during winter months (when I change to my winters) just in case.
