BMW 1 Series 2013 116D (F20) - Bonnet Very Uneven (Photos Inside)
1 reading
5.8K views 26 replies 10 participants last post by  jontymo
Hi All,
Purchased a BMW 116D Sport in November 2015. It was a dark day a bit of a rush and a few other errors on my fault meant that I never really noticed this until a few weeks ago.
Basically, the driver side where the bonnet meets the front light is raised far more than on the passenger side to the point where I've recently been stopped by someone who thought my bonnet was partially open.
After purchase I took it to a friend who works for BMW who did the recalls software update etc he did a full check and said the underside of the car was in perfect condition etc and so not likely to have been crashed. Additionally, all the documents, hpi etc didn't show the vehicle as being in any accident. He said he tried to adjust the gromits on the bonnet to lower that side however it hadn't made much difference but told me noting to really worry about and they're just uneven sometimes.
Me being a perfectionist and wanting the car to be perfect can't really accept this, so I had a read around and a look and thought that it might the physical metal catch just being higher so i've tried adjusting the metal catch to it's lowest setting and additionally lowered the gromit on that side to see if that made a difference.
After doing this and checking I couldn't see any sort of improvement or reduction in the gap. As such this implies it's nothing to do with the actual catch or gromits which are raising this side, so now I'm stuck for what it could actually be? I can't see anything obvious which may have caused this, and when checking the rest of the bonnet line down it seems flush.
Does anyone have any ideas or help? I love the car just really would like to get this resolved.
#5 ·
VO_M135i said:
Does it still have manufacture warranty? If so take to BMW and ask them to investigate as it should not look like that
Yes, until March 2015.
I've tried adjusting the gromits and the bonnect catch to no avail and literally can't see any reason why it should stay this much higher and it's extremely frustrating that I haven't noticed this when buying.
Guess best thing will be to arrange for it to go back and and to see what can be done.
#7 ·
VO_M135i said:
Did you buy direct from BMW? Love the colour by the way
Hi,
No from a BMW re-seller 'BigMotoringWorld' however, probably wish I had gone to a main dealer now.
Really frustrating to be honest, awful dark day and just completely missed it. Due to it being a 3 hour drive to the place and needing a new car we just got it there and then on the day. So I don't think going back and asking them to fix this would likely help me in anyway.
I'm thinking that maybe the bumper is lower on that side? Maybe the light has been replaced possible? That might explain why the rest of the bonnet looks flush?
#8 ·
No way should it look like that - it would never have passed factory QC with that kind of unevenness in the panel gap, so the argument that "they're just uneven sometimes" is b*llocks.
Something is bent somewhere - may not have been crash damage; might just have been someone slamming the bonnet too hard with an obstruction in the way, something like that. But I wouldn't accept it - it shouldn't look like that.
Maybe take it to your nearest official dealer and ask the service dept to have a quick look to determine if it might be claimable under the manufacturer's warranty - the only way it wouldn't be covered is if it is damaged, and in that case, they should at least tell you where and what the damage is so you can go back to the original seller with a complaint.
#10 ·
Thank you for the response.
This is what I'm thinking, that there has been crash damage which has resulted in something bending causing this.
Since this wont be claimable, and I'm imagine would carry a substantial cost to fix? Or would that depend on whats bent and how much?
Then taking it back with a complaint would probably be the best course of action. If they sold it knowingly it has been crashed without telling me I'm presuming this is would be cause for complaint although they'll likely deny knowledge.
#13 ·
jontymo said:
Both 1 series i have had including the same model/year as yours can look like that if the bonnet is not shut with some force, 1 side tends to not engage with the locking mechanism, when this happens i have to open the bonnet and slam it shut again! might be worth trying?
Orignally thought it was that but the lock is engaged.
I just can't figure out where is causing the rise, I've tried adjusting the gromit and catch and they don't seem to adjust this gap at all.
#15 ·
jontymo said:
Having had another look at your pictures i am convinced it is just not shut properly and hopefully nothing to do with any accident damage? get the bonnet open and slam it shut with your hands on top of both side of the bonnet.
The lock does still engage when it looks like that
Theres not alot of give in the bonnet though, if the catch doesn't engage like it hasn't before there is usually alot of give and u can keep pushing it and feel the catch not catching.
However, that side it just genuinely feels solid, like whatever it is resting on.
#18 ·
Looking at the second picture, I'd say the shut line down the drivers side of the bonnet looks OK. That suggests its the bumper out of alignment, unless the whole bonnet has been bent, but that would look pretty obvious.
I'd start by checking the bumper mounting points, and seeing if anything looks asymmetric.
You may struggle taking it back, as they may be able to "suggest" you bent it. A good organisation would take your word, but from previous posts in this thread, it doesnt seem like they are.
#23 ·
jontymo said:
Thats because it will be resting on part of the locking mechanism, if you slam the bonnet shut with more pressure on that side the opposite corner can do the same.
My 1er same as yours did it all the time unless you really slammed the bonnet shut!
I can try it, however, BMW technicians have done the same thing when initially trying to adjust and seems weird that they wouldn't have known it was shut properly or not.
Not sure how forcefully I should be slamming.
#25 ·
HEAVYD said:
Do you mean you wound the stop in towards the bonnet as far as possible. The hood latch might be too low that it isn't engaging fully to pull it fully closed
I've tried it on all length's perhaps lengthening it may solve my issue? But it feels like its caught, as I said when the other side doesn't catch it does not look the same as this side.
Is it possible to lower the actual catch instead? to make that lower?
What it feels like is that the whole thing has caught properly but for whatever reason it doesn't look aligned, the more I look at it if the bumper was pulled up it would look more even, I don't have the measuring equipment to check it accurately though.
I was thinking to check if the lamp had been replaced, any idea if on a production car the lamps would both be the same production age? Or sometimes is it possible that they have different ages on them for whatever reason?
