Favourite and Popular mods
Niall_farley
Post by Niall_farley »
Evening guys and gals! I had a quick trawl but could find anything to match this topic.
It's mainly for fun and to give people (me) a idea of what mods to apply to your own 1 series.
So What are your favourite mods and for what price for what car?
I've not yet picked mine up but ordered a nice steering wheel from royal steering wheels always love his mod! Can't wait to get it fitted.
So what mods would you lot recommend for a 130i? And any other model for that matter
Re: Favourite and Popular mods
Post by marco_polo »
The biggest problem with the standard car is the chassis. Understeery front end, a bobbing bum, and limited grip from the Runcrap tyres.
Luckily the E87 shares it's front subframe with the 1M Coupe / E90 M3, so the longer (negative camber inducing) wishbones and tension struts bolt straight on. Camber pin mod is a freebie, so get that done at the same time. That sorts the front.
The bouncy rear is best sorted with some better dampers and shorter bumpstops. A Bilstein B12 kit (4 eibach Pro springs and 4 matched shorter B8 dampers) are a quick and easy solution. A set of powerflex rear SF bush inserts is a good idea too - cheap + quick & easy to fit.
The Runcrap tyres are easy to swap out for proper ones, just make sure to select XL's (Load index of at least 92). Going 225/40/18 92Y is the most popular.
The rear depends on your preference. 235/40/18 95Y gives neutral handling, 225/40/18 92Y oversteer, 245/35/18 94Y understeer, as an approx guideline.
If you want to go a little further, an E90 M3 front ARB bolts straight on, which is best mated to a 15mm rear ARB. Don't try a 20mm rear, you start to unweight the inside wheel during corners.
With all the extra speed you'll now be carrying, you might want some bigger anchors. M135i blue Brembo 4 pots are quite common now, and bolt straight on (with their pads and 340mm discs of course). M3 brakes don't fit.
After all that, a Quaife LSD would be nice. Relatively easy bolt-in mod on a 130i.
HTH :)
Niall_farley
Wow! Marco_polo! That's impressive didn't expect a reply quite so comprehensive. Tickle me impressed! I shall look in to a number of those mods they sound the bollox to put bluntly
Jfk
Post by Jfk »
Does the camber pin mod yield a noticeable difference as a standalone mod ?
If so , I must get round to doing it.
The only mod I've yet done to my standard 135i is to fit a JB+... That has made a decent difference for 200 quid.
I'm longing for a quaife though , I just can't get on with the standard diff.
+1 for Marco's knowledge
2010 135 i Coupe in Black
The camber pin mod is a small step in the right direction, most people can feel the subtle increase in front end grip. It's not enough for most though, and probably won't give you enough neg to prevent the outer shoulders scrubbing bald after a few roundabouts. :(
The M3 arms you'll need are made by TRW, and can be found inexpensively on Amazon weirdly. Part numbers TRW JTC1423, JTC1424, JTC1426 & JTC1427 - if memory serves.
MegaMinion
Post by MegaMinion »
marco_polo wrote:
Mon Sep 18, 2017 9:27 pm
Do the M3 arms look noticeably different to the standard 1 series arms? ie. are they likely to get spotted if there was a warranty repair on the front suspension?
Sedona Red 2008 E82 N54 135i
No, visually very similar. My E87 went in a few times with full /M3 suspension on and nobody ever mentioned a thing. They're not yellow or anything, just slightly longer. A bit of road-dirt, and few people would ever spot them (shiny new parts are always a bit obvious at first).
The TRW versions are actually original /M3 versions with the logo ground off!
mikeyscott
Post by mikeyscott »
Not got round to doing anything on mine except MPSS tyres and Birds suspension.
Heard people mention CDV too.
Reality is I doubt I'll do anything on mine further as doesn't inspire me.
Gone - 135i E82 2011 AW, Birds B1 Dynamics Package
fmn716
Post by fmn716 »
What's ur guys opinion on H&R swaybar for front and rear
fmn716 wrote:
Wed Sep 20, 2017 6:40 am
I don't like the set-up, the 20mm rear is too stiff. It won't fully lift a wheel during cornering, but it can unweight it enough to cause problems (spins).
Read This: http://babybmw.net/viewtopic.php?f=11&t=102289
Eibach stuff is always better researched and better quality.
fmn716
Post by fmn716 »
marco_polo wrote:
Wed Sep 20, 2017 7:00 am
Just checked the eibach specs
here they are:
Eibach Anti-Roll-Kit BMW 1 (E81, E87)
Information:
Model: 1 (E81, E87)
Engine: 116i, 118i, 120i, 130i, 116d, 118d, 120d, 123d
Year: 08.06
Note: A, 18, 20, 22, 45
Profile Front: Ø 28 mm
Profile Rear: Ø 15 mm
Adjustable Front: Not Adjustable
Adjustable Rear: Not Adjustable
Yup, far superior, much better balance.
fmn716
Post by fmn716 »
I would also like to add a good mod is also the 335i e9x front calipers and disks
fmn716 wrote:
Wed Sep 20, 2017 9:12 am
Quite heavy though, aren't they? Big cast single pots and heavy discs?
I'd go M135i 4 Pot Brembo's instead. Alloy caliper, 2 piece disc with alloy top hat.
fmn716
Post by fmn716 »
marco_polo wrote:
Wed Sep 20, 2017 9:18 am
I suppose so but they good for a budget upgrade 4pot calipers would be first prize :P
