Rumbling sound on start up
Rhysgiles
Post by Rhysgiles » Thu May 24, 2018 12:16 pm
Can anyone tell me what they think this might be been bugging me for ages now https://m.youtube.com/watch?v=1ldaL6h-LiU
Rhysgiles
Re: Rumbling sound on start up
Post by Rhysgiles » Thu May 24, 2018 2:00 pm
You can hear it only happens for 3 seconds then stops. This is after the car has been sitting for a while. Once the engine is warm and I turn it off & on again it doesn’t make that sound. Happened ever since I change the oil one time.
Post by Octavius » Thu May 24, 2018 7:45 pm
Did you use the correct viscosity oil. Sounds like it’s struggling to circulate when cold but okay when warm.
DEFECTED TO SKODA.
Dr.Velasco
Post by Dr.Velasco » Thu May 24, 2018 11:43 pm
I had an 2.4 Accord that did something very similar during cold startups.
It was the VTC actuator, a piece lost it's oil as time went by so upon start up, it will make a brief sound, very similar to your video.
In Honda's case, it was due to a design flaw, but what made it worse, was an incorret oil viscosity, or the engine oil had lots some of it's properties. A quick fix was an oil stabilizer from Lucas Oil. But this was a band aid fix.
2011 130i 6MT
Rhysgiles
Post by Rhysgiles » Thu May 24, 2018 11:52 pm
Octavius wrote:Did you use the correct viscosity oil. Sounds like it’s struggling to circulate when cold but okay when warm.
Yes I’ve use Castrol edge 0w 30, bmw brand 5w30 and now it’s running 5w40 and the service book always has had 0w30 but they all make the noise
Rhysgiles
Post by Rhysgiles » Thu May 24, 2018 11:55 pm
Dr.Velasco wrote:I had an 2.4 Accord that did something very similar during cold startups.
Thanks for the info, so are you saying I should try a thicker oil? I wouldn’t know which to use for mine there is only a select few that I’ve been told I can use for my engine
Dr.Velasco
Post by Dr.Velasco » Fri May 25, 2018 12:08 am
Trying a thicker oil might solve this issue but cause others.
Something that might help is Liqui Moly MoS2 or Ceratec, I'm more inclined to the first one.
Worst case scenario is it does not fix this issue but your engine will run smoother!
When was your las oil change?
2011 130i 6MT
Rhysgiles
Post by Rhysgiles » Fri May 25, 2018 12:14 am
Dr.Velasco wrote:Trying a thicker oil might solve this issue but cause others.
Thanks I’ll give that a whirl! I don’t suppose you know weather the oil control valve is a quick job and where it is located on the n47 engines, they are rather inexpensive so I can’t hurt to replace it.
Dr.Velasco
Post by Dr.Velasco » Fri May 25, 2018 3:08 pm
Sorry mate, can't help you on that one!!
Good luck!
2011 130i 6MT
