F20/F21 M brakes on E82 - Done
Moderators: Lambster, marco_polo, Rich196, babybmwadmin, Producethis
Ben GT
Post by Ben GT » Thu Oct 24, 2013 3:16 pm
Well kind of...
Big thanks to Marco for his patience recently with all the questions I have asked. I'm most grateful :)
So the brakes were pretty much a straight swap on the front but the rears don't fit... yet ;)
On the fronts all was OK in terms of fittings although a few things to be aware of;
1) 18's don't fit over them. You need at least 5mm spacers (I have 261m wheels). I have fitted some temporary 5mm ones but I am waiting on some hubcentric 10mm spacers.
2) The brake discs have 14mm holes for bolts on the F2x, the E8x only has 12mm.
Brake wear sensor didn't need to be swapped, unplugged and re-plugged no alerts or anything :)
The rears won't fit at the moment because of the discs. The hub on the F2x discs isn't as deep as the E82 and therefore it wouldnt fit on properly for the handbrake etc. I hope to find out whether 135i discs may resolve this issue...
So the pics, excuse the quality and the state of the car. I'll try and get her cleaned up and some better pics soon.
5 door 120D LCI ///M Sport + pack | Oyster Leather | Bum Toasters | Driver & Interior Comfort | Black Panel
Re: F20/F21 M brakes on E82 - Done
Post by marco_polo » Thu Oct 24, 2013 3:20 pm
8)
sootyvrs
Post by sootyvrs » Thu Oct 24, 2013 3:32 pm
Glad you got sorted... fronts at least..
I personally think the Brembo 6 pots (BMWP and 135i) brakes gave me more feel than these on my M135i.
2018 F56 Mini Cooper D Man
2018 F87 BMW M2 DCT
2017 F21 BMW M140i Auto
2015 F56 Mini Cooper S Man
2013 F20 BMW M135i Auto
2010 R56 Mini Cooper D Man
2007 E87 BMW 130i Man
Ben GT
Post by Ben GT » Thu Oct 24, 2013 3:56 pm
Well these don't feel as good at the moment as the standard 125i setup.
Hopefully just pads bedding in...
rob180bhp
Post by rob180bhp » Thu Oct 24, 2013 5:09 pm
They look nice give them time to bed in I'm sure they will be fine, did you fit bigger discs also?
Sent from my GT-N7100 using Tapatalk
Instagram "rob180bhp"
Ben GT
Post by Ben GT » Thu Oct 24, 2013 5:18 pm
Yes on the front. Don't think I could really fit any bigger ones on!
rob180bhp
Post by rob180bhp » Thu Oct 24, 2013 5:41 pm
What size are they now
rob180bhp
Post by rob180bhp » Thu Oct 24, 2013 5:51 pm
E92 m3 discs are 360mm and squeeze under 261s
Ben GT
Post by Ben GT » Thu Oct 24, 2013 5:53 pm
Not sure. Rears I can measure they are 360mm and 28mm thick.
Fronts weren't much bigger
Problem with these rears is the hub not being deep enough, much shallower
rob180bhp
Post by rob180bhp » Thu Oct 24, 2013 6:27 pm
The drive flange you mean that has the holes tapped in for the threads
rob180bhp
Wow if fronts are bigger that's huge
rob180bhp
Post by rob180bhp » Thu Oct 24, 2013 6:28 pm
Do you know the thickness of the front discs?
Ben GT
Post by Ben GT » Thu Oct 24, 2013 7:04 pm
Drive flange then! Fronts may not have been bigger, possibly same size but thicker. I didn't measure so can't say for sure
GoldenBunip
Post by GoldenBunip » Fri Oct 25, 2013 10:24 am
wow, they look great, but I'm not at all surprised it feel worse at the moment. With that much imbalance between the front braking force and rear braking it will crab when you brake hard. It's the car equivalent of doing an endo on a bike. Once you have bigger brakes on the rear it will feel and brake much better.
The Orignal 130i
Ben GT
Post by Ben GT » Fri Oct 25, 2013 10:35 am
GoldenBunip wrote:wow, they look great, but I'm not at all surprised it feel worse at the moment. With that much imbalance between the front braking force and rear braking it will crab when you brake hard. It's the car equivalent of doing an endo on a bike. Once you have bigger brakes on the rear it will feel and brake much better.
Thanks, I'm quite certain 135i brakes will get me round the issue...
