E87 cic satnav idrive retrofit
v-spec
Post by v-spec » Mon Feb 15, 2016 7:08 pm
Hi All
Im sure you've seen this type of thread before, and i am hoping some of you may be able to help me.
I plan to do a retrofit cic installation in my e87 118d m sport. It came with a standard BHU and a storage bin in the Dash.
I have just got this:
image hosting 5mb
uploading images
Now im not actually sure what i have or what it does?
its supposed to be a BMW 1er E81 E87 LCI Facelift Navigations system Business CIC MID
Im thinking its just a basic sat nav unit.
What i want is usb, aux input, parking sensors, i drive, gps etc etc
now looking online such as these:
http://www.ebay.co.uk/itm/Bmw-E87-E81-C ... SwL7VWpU21
http://www.ebay.co.uk/itm/BMW-e87-e82-e ... XQj9xRlg6U
The screens seems bigger on these particular models.
My question is this:
What do i have and what can i expect?
can i buy something like this:
http://www.ebay.co.uk/itm/141896284480? ... EBIDX%3AIT
connect it to the screen and im good to go?
yes of course i need to code it blah blah and get all the cables, all something i need to figure out and learn
Hoping one of you can lead me in the right direction.
2008 BMW 118d m sport Sapphire Black
v-spec
Re: E87 cic satnav idrive retrofit
Post by v-spec » Mon Feb 15, 2016 7:15 pm
if i want to do this im going to have to wire this thing up, get the trim for the headunit and the idrive contoller.
Is there a unit that has everything built in i.e usb, bluetooth etc without the need for a seperate combox?
Is it even worth me installing what i have now? Looking at the back of stereo there is no other connections? some of the other units i see online have extra connectors:
http://www.ebay.co.uk/itm/BMW-E90-E91-E ... SwKtVWucS5
jammy78
Post by jammy78 » Tue Feb 16, 2016 5:05 am
it's really not worth retrofitting what you have purchased! That is the revised MASK..... very last of the business CCCs - the give away is the fan on the back.
v-spec
Post by v-spec » Tue Feb 16, 2016 11:03 am
Thanks Jammy
https://www.youtube.com/watch?v=ApKW9Zp9H8c
check this link out?
Same size screen but seems to have the idrive/cic?
Thinking its possible, maybe I just get a different source unit?
v-spec
Post by v-spec » Tue Feb 16, 2016 11:06 am
also it comes with the modern idrive cic controller?
Wibbles
Post by Wibbles » Tue Feb 16, 2016 11:17 am
I wouldn't fit that, it's not CIC and pretty basic.
Apple Carplay - £99 - BabyBMW Special offer!
BRD on Facebook
jammy78
Post by jammy78 » Tue Feb 16, 2016 11:28 am
v-spec wrote:Thanks Jammy
Nope, you got a unit that is just before the newer CIC businesses came out.... these are usually found in the E60s.
Like I said, the giveaway is the fan on the back & the plug on the screen is like a rectangle.... the CIC versions are round & purple.
Absolutely no no point fitting it as its rubbish.
jammy78
Post by jammy78 » Tue Feb 16, 2016 11:29 am
See ebay item: 201508985813
This is a CIC business navs.... notice the lack of the fan & screen connector
v-spec
Post by v-spec » Tue Feb 16, 2016 11:31 am
:shock:
Damn it, ok ill sell it on ebay then!
v-spec
Post by v-spec » Sat Feb 20, 2016 8:39 pm
so lads this is what i have?
Apparently its cic and used the newer menu system not ccc?
Is it worth installing? wondering what hacking i can do, whether i get a new source unit and use that on the screen? Why would it have the newer controller?
or should i just sell it on and save for modern cic unit?
Wibbles
Post by Wibbles » Sat Feb 20, 2016 9:08 pm
It's the business nav & not worth installing.
BRD on Facebook
v-spec
Post by v-spec » Sat Feb 20, 2016 10:05 pm
Thanks wibbles ok I sell it on (hopefully) and use that money to buy a pro cic.
v-spec
Post by v-spec » Sun Feb 21, 2016 8:16 pm
So who on this forum has done a cic retrofit?
Can someone give me a simple breakdown of what parts I need and what is involved?
I can source a professional headunit with a hard drive, controller and screen for around £400-600.
Ive got a matey that works at bmw parts so can get cables and the front fascia etc.
I'll need a centre console that houses the idrive controller, seen these on ebay for around £40-70
My main concern is the o.e wiring harness, does this need changing?
Any help on what to buy and look out for would be appreciated.
V
Wibbles
Post by Wibbles » Sun Feb 21, 2016 8:48 pm
Speak to Maks BMW retrofits on Facebook.
BRD on Facebook
v-spec
Post by v-spec » Sun Feb 21, 2016 9:41 pm
Well Mak seems to be the man looking at his FB page!
I bet he charges an arm and a leg though :roll:
I'll harass him to try and help me :twisted:
