E87 cic satnav idrive retrofit
v-spec
Re: E87 cic satnav idrive retrofit
Post by v-spec » Mon Feb 22, 2016 12:36 pm
Checked out Maks FB page, he's obviously clued up on all things cic and retrofitting! Wonder how much he charges? I was hoping to attempt by own install. I'll reach out to him.
Thanks wibbles
2008 BMW 118d m sport Sapphire Black
Wibbles
Post by Wibbles » Mon Feb 22, 2016 1:41 pm
Best of luck.
BR Diagnostics & Retrofits
Apple Carplay - ONLY £89 - BabyBMW Special offer!
BRD on Facebook
v-spec
Post by v-spec » Fri Feb 26, 2016 5:50 pm
Well ive tried reaching out to Maks retrofit but no reply to my PM's
This is my update so far:
v-spec
Post by v-spec » Fri Feb 26, 2016 6:06 pm
now there's a f@$k lot going on here, so really need some help! I may even consider paying someone to help me retrofit this?
Anyone one on here up for the task?
Wibbles
Post by Wibbles » Fri Feb 26, 2016 10:05 pm
All looks pretty straight forward to me. Do you have a MULF or TCU in the boot for the fibre optic ring?
BRD on Facebook
v-spec
Post by v-spec » Fri Feb 26, 2016 11:09 pm
Hi Wibbles,
This is all new to me, no MUlF or TCU, car came with a basic setup.
So have to run all the cables, optics etc into the boot. Also means learning how to code the car and get it all working together :?
May have to do a dry run on a test bench check it all works before attempting to install it.
Wibbles
Post by Wibbles » Sat Feb 27, 2016 8:53 am
v-spec wrote:Hi Wibbles,
It won't work on a bench unless you have a CAS & JBE test bench.
BRD on Facebook
v-spec
Post by v-spec » Sat Feb 27, 2016 10:14 am
:shock: Thanks again wibbles, ok back to the drawing board, if you know of anyone else that can help me, based in north west London let me know.
redwizard
Post by redwizard » Sat Feb 27, 2016 10:39 am
One of the biggest hassles of upgrading from the basic radio systems to idrive (which a lot of people forget about) is the actual mounting of the CIC unit itself.
It can be bodged (but it will still be a bodge) but the proper way to do it is to replace the complete dashboard. The idrive version (all types) have different mountings for the main CIC/CCC units.
As said before, the CIC/business system (and the CCC systems before that) is just not worth the hassle and expense of retrofitting.
CIC/pro-nav (preferably with DAB) or CIC/NBT is the way to go.
v-spec
Post by v-spec » Sat Feb 27, 2016 2:40 pm
That's true redwizard of oz, I realise ill have to cut and chop into the central dash to fit the unit.
Its worth it for me as its still a good system upgrade and from what I've seen it can be done.
I can always add DAB afterwards but im doing this on a budget and trying to find time to do it is hard enough with work and family commitments.
I'll be well chuffed when it in anyway
atl_23
Post by atl_23 » Sat Feb 27, 2016 6:04 pm
Im based in NW too, just outside the M25.
If you need a side-kick, not that I know as much as these guys, then hit me up. I'm also in the process of figuring out how to upgrade to SatNav...
This is ideal in my mind, but doesn't fit my car due to heated seats function. - http://www.amazon.co.uk/dp/B005WGTAS0
BMW 120d MSport - 2Do: Xenon Fog Lights / Front Splitter / ECU Remap 210bhp
redwizard
Post by redwizard » Sat Feb 27, 2016 6:48 pm
v-spec wrote:I can always add DAB afterwards but im doing this on a budget and trying to find time to do it is hard enough with work and family commitments.
You can add DAB as a separate unit to any system, but you can't beat an integrated unit.
It's all down to budget in the end - better not browse on here too often then. :lol:
v-spec
Post by v-spec » Mon Mar 07, 2016 9:38 pm
Guys so i'm preparing to fit this myself, but need some advice and help.
Please could you look at the pictures and tell me if what i have labeled and connected look right?
v-spec
Post by v-spec » Mon Mar 07, 2016 9:41 pm
Also with regards to the combox, what does this particular combox allow me to do? What features can it give me?
I know you usually place this in the boot, but it seems the wiring loom i have is short, can i place this in the dash, under the seat?
I also have an issue with the most fibre optic cables, i'm told i cant make my own as they need to be specially cut and fitted to the connectors? how would one go about doing this?
Wibbles
Post by Wibbles » Mon Mar 07, 2016 9:49 pm
In answer to the questions above - the black connector on the combox is for the snap in baseplate under the armrest.
The fibre optics are required for the combox to work - new cables can be bought at your dealer.
The combox will give a full speed USB, BT streaming, BMW Apps (with the right CIC firmware or FSC code).
BRD on Facebook
