Cruise control retrofit
jammy78
Re: Cruise control retrofit
Post by jammy78 » Sun Jul 31, 2016 2:18 pm
No, I didn't remove any codes.....
The part numbers on the slip rings are the same..... but first, I'll make sure buttons work with the original ring & stalks.
EDIT: buttons work with original slip ring!
I'll update when finished.
Cheers for the heads up on the coil!
Wibbles
Re: RE: Re: Cruise control retrofit
Post by Wibbles » Sun Jul 31, 2016 3:07 pm
jammy78 wrote:No, I didn't remove any codes.....
My cheque is in the post?
Apple Carplay - £99 - BabyBMW Special offer!
BRD on Facebook
jammy78
Post by jammy78 » Sun Jul 31, 2016 3:16 pm
Yes mate..... you were spot on with the cause!
Swapped over the slip rings & everything is working! Not sure I liked coding the whole car.... prefer doing the individual modules.
Next on my list - heated leather seats....... Haven't got time today to put down the new wiring.... next weekend!
:spotman:
Wibbles wrote: My cheque is in the post?
On its way with a big fat kiss (?)! :lol:
Thanks again!
jammy78
Post by jammy78 » Sun Jul 31, 2016 3:28 pm
Just to show pics of the fault:
What I think has happened - the slip ring had done a few rotations & the ribbon was at the max prior to install (ie you can only turn the steering wheel so much before you lock).
So when I installed the part & turned the wheel, the ribbon broke (I actually hear it snap but at the time, didn't know what it was).
Anyway - To all..... prior to install, I'd take the cover off & just ensure it hasn't been rotated too many time, otherwise this will happen to you!
Wibbles
Post by Wibbles » Sun Jul 31, 2016 8:02 pm
That's what usually happens, happened to me which is why I knew what the issue was immediately :)
BRD on Facebook
59hopper
Post by 59hopper » Mon Aug 01, 2016 9:13 pm
Hi All,
I'm new to the forum and have recently purchased a 57 plate 123d Msport Coupe. Loving the car so far and now looking to fit cruise control.
I have read through all the guides and this thread and now know I need to order part 61319123040 as I have MFSW and non-auto wipers. However I have found two versions of this part with different centres, can someone please advise which one I need, I'm really sorry if this has already been answered but my car is due in the local garage for this next week and I need to order the right one...
Should it be flat fronted like this one;
http://www.ebay.co.uk/itm/131874109498
Or should it have connectors like this one;
http://r.ebay.com/rnsNfQ
Thank you.
Alex :-)
Sent from my D5803 using Tapatalk
59hopper
Post by 59hopper » Mon Aug 01, 2016 9:18 pm
Also one other quick question, real oem has the following note which is likely to be applicable to my car...
On vehicles produced up to
10/31/2008, before ordering the
steering column switch module
refer to PUMA measure 28753830 as well as the repair manual REP 61 31 009.
Does anyone know what this actually means and will this affect the parts I need to order?
Thank you again.
Alex.
jammy78
Post by jammy78 » Tue Aug 02, 2016 8:28 am
Hi Alex,
I have the part you need for sale......
http://www.babybmw.net/viewtopic.php?f=60&t=88640
8)
59hopper
Post by 59hopper » Tue Aug 02, 2016 10:45 am
Thanks jammy78, I have sent you a PM :-)
59hopper
Post by 59hopper » Fri Aug 05, 2016 2:17 pm
Afternoon All,
Now that I have all the parts required to retrofit,
is there anyone who would be able to fit and code for me locally?
I am based in Norwich, Norfolk but happy to travel within East Anglia Area. A local garage has agreed to charge me £120 to fit and code the parts but would much rather have a forum expert work on my pride and joy...
Alex
jammy78
Post by jammy78 » Fri Aug 05, 2016 8:41 pm
59hopper wrote:Afternoon All,
Alex
£120 :? for 5 -10 min work!
Edit.... Fit as well - not a bad price!
bung206
Post by bung206 » Sun Aug 07, 2016 12:24 pm
Can someone tell me which cable is needed to code a 2011 E82? There are so many options on ebay not sure which one is correct!
Wibbles
Post by Wibbles » Sun Aug 07, 2016 12:25 pm
DCAN cable from www.cable-shack.co.uk
BRD on Facebook
59hopper
Post by 59hopper » Fri Aug 12, 2016 10:15 am
The good news, is that my cruise control has now been fitted and is working great and the display is showing the speed when set etc. :)
The bad news, is that the multifunction buttons have now stopped working :?
Will need to take the car back to the garage in a week or so...
Post by Twenny » Fri Aug 12, 2016 10:33 am
Wibbles wrote:DCAN cable from http://www.cable-shack.co.uk
This one ok Wibs?
https://www.ebay.co.uk/itm/262131709998
Return to “How To's”
