Performance Short Shift Gear Lever Kit
Re: Performance Short Shift Gear Lever Kit
Post by marco_polo » Mon Oct 31, 2011 9:05 pm
Thanks for this guide Sonic, just used you guide to fit 'Dan116i's short shift kit.
Took me a good half an hour or so, even with your instructions!
If anyone else is following this, I'd suggest turning the white plastic socket-cup 90 degrees clockwise, it pops up nicely then. Before you start, check out the tabs on the new socket-cup supplied in the kit, and the two long slots either side of the metal outer ring. You can just see the slots in Sonic's pic, the light is bouncing nicely off the right hand one.
stig123
Post by stig123 » Fri Aug 03, 2012 8:55 pm
does this guide work exactly the same for 123's ?
Post by marco_polo » Fri Aug 03, 2012 9:08 pm
Yup, 116d's through 130i's.
stig123
Post by stig123 » Fri Aug 03, 2012 9:14 pm
im having problems with the bit that you posted marco,
the white plastic socket seems to be sealed in rubber :?
Post by marco_polo » Fri Aug 03, 2012 9:18 pm
Rubber? :?
Photo please.
stig123
Post by stig123 » Fri Aug 03, 2012 9:37 pm
in the first pic, under the black band is a rubber housing . is this normal?
Post by marco_polo » Fri Aug 03, 2012 9:40 pm
Yup, that all looks normal.
First remove the weight/damper on the shaft, by squeezing both ends of the spring clip together. This will need to be transfered over to the new stick later.
Once off, remove the rubber weather gaitor. :)
sonicvanman
Post by sonicvanman » Sat Aug 04, 2012 10:03 am
sonicvanman wrote:Second is to remove the plastic trim & gear stick gaiter, then rubber casing around the stick
stig123
Post by stig123 » Sun Aug 05, 2012 7:10 pm
after rotating the ball socket it has popped up a little bit but is it suppose to completely come out or am i suppose to pull on it ???
Post by marco_polo » Mon Aug 06, 2012 8:56 am
Have you released the circlip and slid the selector rod off? Some people find this stage easier from under the car.
stig123
Post by stig123 » Mon Aug 06, 2012 11:11 am
Iv not released the circlip bcos i cannot access it from in the car
Damm il have to jack the car up now & get underneath it !
Post by marco_polo » Mon Aug 06, 2012 2:28 pm
Yup, jack her up if needs be, tranny undertray off if necessary, and then you're away. :)
beattie17
Post by beattie17 » Fri Aug 31, 2012 3:13 pm
Can you buy just the short shift lever part?
Space grey 135i N55, 461bhp/537lbft, Ecotune hybrid & map, VRSF Fmic, Wagner DP, Berk Race Axle Bk, Pure inlet, BMS chargepipe & induction kit
Instagram: beatt1e
Post by marco_polo » Fri Aug 31, 2012 3:14 pm
Yup.
beattie17
Post by beattie17 » Fri Aug 31, 2012 8:53 pm
Cheers. Where can i buy it? dealer?
Instagram: beatt1e
Return to “How To's”
