Page 2 of 4
Re: Performance Short Shift Gear Lever Kit
Posted: Mon Oct 31, 2011 9:05 pm
by marco_polo
Thanks for this guide Sonic, just used you guide to fit 'Dan116i's short shift kit.
Took me a good half an hour or so, even with your instructions!
If anyone else is following this, I'd suggest turning the white plastic socket-cup 90 degrees clockwise, it pops up nicely then. Before you start, check out the tabs on the new socket-cup supplied in the kit, and the two long slots either side of the metal outer ring. You can just see the slots in Sonic's pic, the light is bouncing nicely off the right hand one.
Posted: Fri Aug 03, 2012 8:55 pm
by stig123
does this guide work exactly the same for 123's ?
Posted: Fri Aug 03, 2012 9:08 pm
by marco_polo
Yup, 116d's through 130i's.
Posted: Fri Aug 03, 2012 9:14 pm
by stig123
im having problems with the bit that you posted marco,
the white plastic socket seems to be sealed in rubber :?
Posted: Fri Aug 03, 2012 9:18 pm
by marco_polo
Rubber? :?
Photo please.
Posted: Fri Aug 03, 2012 9:37 pm
by stig123
in the first pic, under the black band is a rubber housing . is this normal?
Posted: Fri Aug 03, 2012 9:40 pm
by marco_polo
Yup, that all looks normal.
First remove the weight/damper on the shaft, by squeezing both ends of the spring clip together. This will need to be transfered over to the new stick later.
Once off, remove the rubber weather gaitor. :)
Posted: Sat Aug 04, 2012 10:03 am
by sonicvanman
sonicvanman wrote:Second is to remove the plastic trim & gear stick gaiter, then rubber casing around the stick
Posted: Sun Aug 05, 2012 7:10 pm
by stig123
after rotating the ball socket it has popped up a little bit but is it suppose to completely come out or am i suppose to pull on it ???
Posted: Mon Aug 06, 2012 8:56 am
by marco_polo
Have you released the circlip and slid the selector rod off? Some people find this stage easier from under the car.
Posted: Mon Aug 06, 2012 11:11 am
by stig123
Iv not released the circlip bcos i cannot access it from in the car
Damm il have to jack the car up now & get underneath it !
Posted: Mon Aug 06, 2012 2:28 pm
by marco_polo
Yup, jack her up if needs be, tranny undertray off if necessary, and then you're away. :)
Posted: Fri Aug 31, 2012 3:13 pm
by beattie17
Can you buy just the short shift lever part?
Posted: Fri Aug 31, 2012 3:14 pm
by marco_polo
Yup.
Posted: Fri Aug 31, 2012 8:53 pm
by beattie17
Cheers. Where can i buy it? dealer?
